Go Back   Automotive Forums Car Chat > Opel/Vauxhall > Commodore/VS/VT/VX
Old 03-31-2002, 06:07 AM
keegs01 keegs01 is offline
Send a message via AIM to keegs01
Lightbulb Holden superchared
hey, i am wondering what the costs are of either the vortec or powerdyne superchargers are roughly. Needs to be fully installed on a v6 ecotec vt series 1. What would a rough estimate in power increase be. Does the supercharger require and aftermarket management contrl system or can it be ran without one like i have heard. Has anyone had any trouble with these sort of supercharges? Also i hav heard that the cruzing neon as seen in fast and the furious is illegal in aus? is this true?
Thanks for anyhelp.
Skaife, ur the F@#kin king.
Old 05-06-2002, 11:11 PM
VK_KING VK_KING is offline
prob about 8grand fully installed
It might be cheaper just to buy a supercharged(from the factory) vt and just work that engine a little it wil save you a lot.
the other option is to buy a kit which uses a old jap supercharger these are availaible for around two grand.
Old 05-07-2002, 02:59 AM
replicant_008's Avatar
replicant_008 replicant_008 is offline
warming the super...
The factory supercharged engine has no intercooler so you safely assume that adding one should improve on the efficiency of the setup (as long as you figure plumbing and locating the sucker) as the cooled gas is more efficient to push into the combustion chamber.
Varying the size of the pulleys will affect the gearing of the supercharger so you can theoretical get more boost up to the maximum CFM that the turbine volume and speed will allow (ie make the driveshaft pulley bigger and the supercharger pulley smaller).
I don't know the formulae but once you get close to the maximum cfm of the swept volume of the impeller the greater the proportional increase in speed required for each additional lb of boost. In other words, you have to really push a lot of air at faster and faster speeds thru the intake tract before the boost actually increases unless you can make the impeller bigger. Hence that's why you need a bigger turbo not a faster turbo in most cases to get more boost. Also increasing the impeller speed also introduces issues re bearing and spindle wear/failure.
Compression/knocking/detonation becomes an issue at higher boost levels too.
The last issue I can think of is injector volume - it's all very well putting more boost in but you need the fuel to add to the mixture in sufficient quantities to make the appropriate fuel:air ratio for maximum efficiency.
As you increase boost the more fuel you need, which means injector volume or duration increases and fuel supply...
Old 08-30-2002, 01:14 AM
farking_funny farking_funny is offline
About $4,500 fully fitted.
Old 09-04-2002, 12:41 PM
ak69 ak69 is offline
Re: Holden superchared
Thanks for anyhelp.
Yes those lights are illegal here in australia,They "say" its a hazzard and they defect your car if you have them on
Still it dont stop some people
Old 11-14-2003, 09:09 PM
86_SR5's Avatar
86_SR5 86_SR5 is offline
Re: Re: Holden superchared
It's illegal in the US too.
RIP Indian Larry RIP
April 28th, 1949 - August 30th 2004
IN GOD WE TRUST
VENGEANCE IS MINE
SAYETH THE LORD
NO FEAR
Old 01-12-2005, 04:24 AM
vx_supercharged vx_supercharged is offline
Go the factory supercharged!!!
I've got one and it and it goes pretty hard standard
http://www.v6supercharged.com.au/
Cheack out this site - they do up the stocko superchargers
Old 01-21-2005, 08:36 AM
-Davo's Avatar
-Davo -Davo is offline
Banned
That site kicks ass! There is a vid one of the supercharged commodores doing 0-100 in 3 seconds! HOLY SHIT!
Damn! My VS does 0-100 in 7.9 seconds!
Old 12-03-2006, 01:55 AM
[PSI-EFI]'s Avatar
[PSI-EFI] [PSI-EFI] is offline
www.capa.com.au - this is ur solution. i would just buy an l67 and be done wif it.
