Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 03-30-2005, 11:57 PM
TIDEWITHBLEACH TIDEWITHBLEACH is offline
93 Dakota problem
I am having some kind of ignition problem with my 93 Dakota. When I start the car cold every thing works as it should but if I say drive to the store it won’t start sort of. It will crank and start up but then immediately die. If I keep give it gas it will keep running but once I let off the gas it will die. I have to put it I drive with my foot on the pedal. Once I drive over 20 for block it will stop dieing and work perfectly. I was thinking it might be some sort of computer problem. Any one heard of some one with a simler problem of any clue?
Thanks for any help
Old 04-03-2005, 01:15 PM
I found a consumer report that talks about a “Rough idle” problem because of a problem with the idle air control motor especially in warm weather. http://auto.consumerguide.com/Auto/U...ewreliability/
So I replaced the idle air control and it works great now.The part was Niehoff Ignition 21821 if anyone has the same problem
Old 07-06-2005, 08:57 AM
connorwj connorwj is offline
92 with 5.2
hey I've got the same problem. Car would start, but could only keep it running with foot on gas and brake. have you found out anything new? The problem for me has been intermittent, but yesterday was constant for about 6 hours. Any info I can get would be appreciated.
Old 07-06-2005, 04:17 PM
have not have a problem once i replaced the idle air control
Old 07-06-2005, 04:29 PM
Gizmokid2005 Gizmokid2005 is offline
Send a message via AIM to Gizmokid2005 Send a message via MSN to Gizmokid2005 Send a message via Yahoo to Gizmokid2005
Re: 93 Dakota problem
If that doesn't work, I had the a similar problem, I had to replace the EGR Valve.
