Old 03-30-2005, 08:11 PM
Sunliner Sunliner is offline
Rattling noise
I've got a '97 Blazer LS, 4.3, 2wd
There is a rattling noise-sounds like metal rattling against metal-coming from the underside of the truck.
Only seems to do it when the truck is sitting still & in gear. Seems to be a little louder in reverse than drive though. Goes away when I release the brakes & start rolling.
I'll mention this in case it's related...lately I also have an occasional "clunk" when first taking off. I think that may be a u-joint but I haven't had time to check those yet.
Also had the rear main oil seal & oil pan gasket replaced not too long ago, so I'm wondering if the rattle is related to a motor or transmission mount (?) that was loosened to get to those jobs.
Any idears?
-Mike
Old 03-30-2005, 09:12 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Rattling noise
Rattle: Cat Convertor
clunk: u-joint- probably the rear one.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-31-2005, 07:39 PM
Ok, that makes sense...so another question...if I understand correctly, the cat generally shouldn't fail unless something else is wrong (?)
Other than the aforementiond "clunk" which shouldn't affect the converter, the Blazer has been running great....would it make sense to go looking for the cause of the cat rattling, or just wait & see what happens?
Thanks!
-Mike
Old 03-31-2005, 07:50 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Rattling noise
I had a rattle like the one you described, it was the the skid plate that covers the tranny and transfer case. One bolt was missing and the others were loose.
Old 03-31-2005, 08:04 PM
k5dan's Avatar
k5dan k5dan is offline
Send a message via Yahoo to k5dan
Re: Rattling noise
I think the cat rattle he was refering to is a heat shield on the cat that has broke loos since it is only spot welded together or of course it could be some broken catalyst inside the cat.
-->1994 Ford Thunderbird LX 4.6l V8, auto trans. Completely Stock
-->1989 Dodge Dakota 3.9l v6, 5 speed manual trans, 4x4
