Old 03-30-2005, 07:48 PM
waynebat waynebat is offline
Send a message via Yahoo to waynebat
HF to Si..1991
I just replaced my tired HF engine with an not so tired Si engine. I used my 8 valve head on the Si engine cause the valves were stuck on the 16 valve Si engine and the intake on my head has the EGR on it so everything plugged right in. Then the nightmare started. I have been able to get the engine started only once and then again and then never more. I tried switching computers, and distributors and fuel resistors and back again. I got a spark when I unplugged a MAP sensor plug and then that spark went away. What is happening here? HELP........
Old 03-31-2005, 12:48 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: HF to Si..1991
check compression
Team Lonely Drivers
Old 03-31-2005, 07:42 PM
Re: Re: HF to Si..1991
Excellent compression. I seem to have a problem getting spark. I just tested the igniter and there is no continuity from the white wire to body ground or the blue wire to body ground. Now what? Tried both distributors. Could they both be bad?
Old 04-06-2005, 07:19 PM
Re: Re: Re: HF to Si..1991
Ok, I got her started. Now I have a map sensor code blinking on the ecu. She runs a little rough and backfires and the tach is going nuts. Is there something else I should change here? Anyone know anything about this kinda swap?
Old 04-06-2005, 07:53 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: HF to Si..1991
Great, but what does this have to do with JDM motors and parts?
NOTHING.
So I moving this to a forum better suited for this question.
Old 04-06-2005, 09:30 PM
Scott82 Scott82 is offline
Re: HF to Si..1991
Did you change any wiring at all? or it sounds like it may be out of time if it is running rough and backfireing. try moving the dizzy aroung and see what you get or if it gets better or worse, but i dont think the map sensor would do all that.
Old 04-07-2005, 10:38 PM
SORRY...Maybe you will put it some where where somebody knows what I am doing?
Old 04-07-2005, 10:39 PM
I did change the ecu and the distributor and that is how I finally got it started. I am getting closer now. Thanks for the reply.
