Go Back   Automotive Forums Car Chat > Mitsubishi > Mirage
Old 03-30-2005, 07:11 PM
95mirage 95mirage is offline
Which order do you intall plug wires? HELP!
I just took off all my spark plug wires to install new ones. But now I dont know in which order on how to plut them back. Can someone tell me or even better show me a pic. This is for a 95 Mirage 1.5
Thanks
Old 04-01-2005, 01:08 PM
diymirage diymirage is offline
there should be a cylinder 1 mark on yer distributer cap and the firing order might be on a sticker under the hood , if not it is in your manual
cylinders are always counted from the timing belt so cylinder one should be the driver side one (if they didnt rotate the engine in the 5thG)
now all you need to do is figure out if yer distributer is clockwise or counter clock wise but you can tell by just hooking up the wires and see how it runs .
if you think it might not be firing on a certain cylender just pull the plug and if the idle doesnt change that wire was in the right spot
it might take a couple of tries but it is garantueed to work
