Old 03-30-2005, 07:03 PM
trueblazer94 trueblazer94 is offline
94 Blazer won't start
Hey guys i've been searchin all thru the site n i cant figure out the solution to my problem...
1994 s10 blazer 4.3l vortec 180k miles
The thing is, it had previously been running like crap misfiring, stumbling, stalling. It would still start right up no problem. After running it at idle for about 10 minutes one day, it wouldn't start up again. So, I went and spent $300 on a new CPI injector unit and got that all installed.
No change.
It will crank and crank but wont turn over.
I've checked fuel pressure, everything is where it should be.
Spark seems to be good, new plugs(fouled quickly but i cleaned them), cap and rotor. Could I possibly need an ignition coil even though there is a good amount of spark?
New EGR valve, Battery, Alternator...
What else would stop it from starting!?!?
Any ideas on this situation? One day it starts up fine, the next, nothing??
I'm at a loss and have no idea what's going on....going crazy!
Any help greatly appreciated.
Old 03-30-2005, 07:57 PM
jsgold jsgold is offline
Had the ignition module go out on my 93 a few months ago.(Random starting, would not start until set for a few hours) I was fooled into thinking it was a fuel problem as I could get it to hit on starting fluid. It turns out it was not firing strong enough and was firing randomly. Replaced coil and module. No problem since.
I used to be indecisive, now I am not so sure.
Old 03-30-2005, 09:18 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 94 Blazer won't start
What's the fuel pressure?
Key on with the engine off.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-31-2005, 02:39 PM
Re: Re: 94 Blazer won't start
Last time checked seemed to be plenty it was 58-60
Old 03-31-2005, 09:39 PM
BlazerLT's Avatar
AF -Advisor
Would it hold the pressure, or would it bleed off quickly?
Old 04-01-2005, 02:41 PM
It would hold steady, I've yet to check compression again because I did an oil change and the old oil was full of gas. Who knows...
Old 04-01-2005, 03:33 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: 94 Blazer won't start
That is a sign that you have to replace the cpi injector and the nut kit inside of the plenum.
Old 04-01-2005, 05:05 PM
k5dan's Avatar
k5dan k5dan is offline
Send a message via Yahoo to k5dan
he already said he replaced the cpi injector
-->1994 Ford Thunderbird LX 4.6l V8, auto trans. Completely Stock
-->1989 Dodge Dakota 3.9l v6, 5 speed manual trans, 4x4
Old 04-01-2005, 06:22 PM
CPI and Nut Kit both replaced recently...I'm pretty sure its not a fuel problem.
First, the nut kit went, replaced it, then it worked fine. Next, it starts having similar problems but worse than before. Thats when I got the new injector. I'm still not sure if will run smooth or not when and if I get it running. Ignition module is out of the question, right?
Old 04-01-2005, 07:46 PM
BlazerLT's Avatar
AF -Advisor
If you have gas in the oil, you bet your bum it is a fuel problem.
Old 04-13-2005, 10:09 PM
Talking Re: Re: 94 Blazer won't start
Oh yeah get this...NEW PLUGS AND WIRES did the trick! How crazy is that?? Stilling running rough, but gonna run the computer and see what codes it throws out. Hopefully it'll be back to normal soon. I'm just glad it finally STARTS. Now I won't have to tow it.....=)
Old 04-13-2005, 10:25 PM
BlazerLT's Avatar
AF -Advisor
You need to get the timing set back to zero with a timing gun and the timing wire unattached.
Set the timing to zero and reconnect the timing wire.
Also, have you ever replaced the cap and rotor?
Old 04-14-2005, 08:53 PM
True, I must fix the timing. The cap and rotor have been replaced not too long ago (1 yr?) . Do you think it would be good to replace them again? Also, do you think any sensors could be a problem? MAP, Throttle position, Air control, EGR cleaning, etc? Thanks
Old 04-15-2005, 12:40 PM
BlazerLT's Avatar
AF -Advisor
Make sure the timing is set properly and move on from there.
Old 04-15-2005, 02:43 PM
Got the scanner today...gonna see whats up with this...thanks again
