Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 03-30-2005, 06:43 PM
drparkwood drparkwood is offline
Olds 88 A/C Clutch not engaging
I have a 96 Olds 88, the AC compressor failed, so I replaced it. The Freon charge is OK, fuses OK, clutch won't engage at all. How do I jump the relay to check if it's the relay?
Thanks
Doug
Old 04-01-2005, 06:13 PM
diesel1962 diesel1962 is offline
Re: Olds 88 A/C Clutch not engaging
Hello! What you want to do is remove the cover on the Maxi-Fuse center,There you will have acess to the dryer(Large silver object),You will see the refridgerant line runs to it.There you will fine a electric plug,This is the pressure switch.Unplug the wire harness and get a paper clip or wire,And jump the two connections.Compressor should engauge,Or you may have a bad relay.Do you know if you have enough compressor oil in the pump? There should be another switch at the pump montering compressor oil.Do you have a gauge to know exactly how much refridgerant is in the system? Too little,Or too much will make the clutch not engauge.Let me know what you come up with.Have a good day!! Diesel1962
Old 04-02-2005, 05:48 AM
auto trainy auto trainy is offline
I would also check to see if the clutch on the replacement compressor is good.
