Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 03-30-2005, 05:54 PM
98tahoelady 98tahoelady is offline
Unhappy 98 tahoe wont start
it cranks but wont catch- not fuel pump or fuel filter- once started stays running... please help a lady out
Old 03-30-2005, 08:27 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: 98 tahoe wont start
check the fuel pressure. it needs to be at around 60psi or the injectors won't inject.
Old 03-31-2005, 12:36 PM
SpitAndDirt's Avatar
SpitAndDirt SpitAndDirt is offline
High miles? Cap and Rotor contact points burnt out. Probably Original, Replace Cap and Rotor
Old 04-01-2005, 06:19 PM
sdgoat sdgoat is offline
Send a message via Yahoo to sdgoat
Your problem is your fuel pump, I am almost sure of this. When you turn on your ignition, do you hear your fuel pump run, prime the system? It will only do this from a cold start, after the system is primed, it will hold this prime for quite a while before it has to be primed again. Try it, turn the key on after it's set for a couple of hours. If you don't hear the fuel pump run for about three seconds, that's your problem. There was a TSB on the pigtail to the fuel pump which is located inside the fuel tank. Good luck
Old 05-13-2005, 11:57 AM
clearman clearman is offline
same issue here on an 02. mechanic says it is the idle aircontrol, but with all these fuel pump issues on Tahoes I certainly am not ruling that out.
Old 06-01-2005, 02:58 PM
GiGsolydCustoms GiGsolydCustoms is offline
my 97 tahoe does the same thing. as a matter of fact thats why i joined the site. what im doing to keep it running is using a can of Seafoam fuell line treatment. it seems to be the only thing that keeps it running. im thinking that i have a huge carbon build up inside the intake and t.b. keep posting if anyone knows anything better-please
