Go Back   Automotive Forums Car Chat > Ford > E Series
E Series Forum covers questions and discussions regarding Ford E-150, Ford E-250, Ford E-350, and Ford E-450.
Old 03-30-2005, 04:58 PM
medone medone is offline
Unhappy E350 7.3 Lt Diesil
Looking For Info On The Location Of Fuel Filter For The Above Model Not Quite Sure If Under The Body Or On Motor, Any Help Would Be Appercated Thanks
Old 04-05-2005, 08:51 AM
ModMech's Avatar
ModMech ModMech is offline
Re: E350 7.3 Lt Diesil
What year?
Old 04-06-2005, 07:49 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
It should be attached to the engine just in front of the passenger side valve cover. It is a spin-off kind and looks just like an oil filter.
Old 04-06-2005, 08:30 PM
ModMech's Avatar
Depends on the year. If it's newer than a '93, that's wrong.
Old 04-12-2005, 01:18 PM
ltbuick ltbuick is offline
It is a black cap at almost center on front of engine, just right behind high pressure oil pump housing. Top of cap almost looks like spider webbing. if you had not had off for awhile may be tight, you can use oil filter wrench to grab top of cap. you will have to move air muffler just loosen clamp and seperate from hose. if air muffler does not want to budge loosen support nut on passenger valve cover.
