Old 03-30-2005, 04:04 PM
Scott82 Scott82 is offline
Is this safe to do?
This is probably a dumb question, but is it safe to start the motor befor i get my axels in and fluid in the trans as long as i keep it in neutral? Reason i am wondering is i am about to wrap up the motor end of my swap, but i still am going to put on new shocks, ball joints, tie rod ends, ect and i really can't wait to hear it run and plus if something is wrong then there is less to take apart if i need to get to something. Thanks Scott
Old 03-30-2005, 04:13 PM
clawhammer's Avatar
clawhammer clawhammer is offline
Re: Is this safe to do?
Probably not.
http://www.mototuneusa.com/break_in_secrets.htm
Old 03-30-2005, 04:40 PM
Ones&zeros Ones&zeros is offline
Send a message via AIM to Ones&zeros
i think neutral still spins the tranny, maybe if you push the clutch down it'll be safer.
Old 03-30-2005, 05:52 PM
I was just curious if any one had done this before but i guess paitence is a is good practice and i should go ahead and get it all put together.
Old 03-30-2005, 06:27 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
fuck that man, start that beast up!! Theres nothing wrong with doing it for a little bit. Should keep the clutch in, but even if you didnt you more than likely wouldnt cause any damage. Like you said, if theres something wrong, theres that much less to take apart to get to it. good luck
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 03-31-2005, 03:58 AM
stang805's Avatar
stang805 stang805 is offline
Send a message via Yahoo to stang805
the tranny will probably still spin wheather you push the clutch in or not, especially if its not adjusted, it shouldnt hurt anything to start it but i wouldnt sit around rappin it up for a half hour to listen to it
Old 03-31-2005, 07:02 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
With the clutch engaged and in netural the input shaft will spin, nothing else should spin when in netural. With the clutch dis engaged only the clutch will spin. Should be safe.
Old 03-31-2005, 07:05 AM
clawhammer's Avatar
Did you change anything on the internals, like new piston rings? If so, then read the article that i posted. Otherwise, I'd still wait, don't take a change.
Old 03-31-2005, 09:08 AM
no didn't change any internals, just gaskets, thermo, ect. Just pretty much everything external
Old 03-31-2005, 09:14 AM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
what I'd worry about is that either one your not going to have oil in the tranny, and the input shaft may spin if your clutch catches at all, and two if you do put fluid in, it'll be all over the place.
I'd put the axels in and just put the control arms and rotors in place loosely
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 03-31-2005, 09:19 AM
cool thansk for everyones help
