Taurus to Continental?
Could anyone tell me what year of Taurus stuts will fit a '92 Continental. A friend of mine has the front struts that fit an'88 to '92 Taurus and I was wondering if those would work. Thanks,Jubil22
Re: Taurus to Continental?
The struts from a Taurus will fit as far as size and capacity are concerned. However, you will have to do several modifications for the mounting brackets and plates. The Taurus struts are NOT A BOLT IN SOLUTION. There are some modifications you have to make before they can begin to work. Also you run into a problem with load capacity. The Continental is much heavier in the front than a taurus. The strut itself should have the rebound and compression as a conti strut but you would have to change the springs to support the weight. If you ask me all of that is a VERY big head ache.
Re: Re: Taurus to Continental?
GREAT!! I am glad that you did not run into any problems. Sounds like you came out real good. Congratulations..
