Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 03-30-2005, 02:51 PM
bigdogg bigdogg is offline
A/c
A/C leaks. Can't find where the leak is. Mechanic wants to replace entire system. Can anyone help me locate the leak. Don't know where the lines run in the rear of vehicle.
Old 03-31-2005, 01:16 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: A/c
Inject some dye in it and use a blacklight. If no results, use a sniffer in the vents, in case the leak is in the evaporator. I'd say your mechanic just wants more money, or doesn't know much about A/C.
Also, what year is it, and how much/how fast is it leaking?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
