Do the brand of spark plugs and wires have to be the same??
Hi all.....I replaced all my spark plugs about 2 months ago because I had a cracked one and my car was at about 40,000 miles....the car has been running great since then, but for the last couple days at a stop light or in idle it will feel like its about to die....should I replace the wires too.and does it matter what brand I use{ I used bosche platinum plugs}Also somebody told me it just might be bad gas since it happend a day after I filled my tank up from a place I dont usually go...it this a symptom of bad gas....any help would be appreciated...thanks
Re: Do the brand of spark plugs and wires have to be the same??
Sound's like it maybe a problem with the Gas,I always try and stick with name brand,Mobile,Shell,ect,ect...I got bad gas on an older car and had to have the carb rebuilt and only thing I found was lots of moister,then dumb me
,a few months later I stoped at the same station and the same thing happened again.So I learned my leason on buying from a no name station.You might try some HEAT or fuel additive before replacing the wires and top it off with some good fuel.Also might not hurt to replace the fuel filter.~Larry~
Re: Re: Do the brand of spark plugs and wires have to be the same??
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
If you suspect the gas may be the problem then siphon it out and refill with good fuel. If your car has an electric fuel pump you can also disconnect the fuel line at the filter and turn the key on to pump it out. Be careful if you do this, it will come out under high pressure. I only go to Amoco, Shell, or Mobil and never use additives. My Jeep has 170,XXX miles on it and never had any injectors cleaned or replaced. Whether this is proof of a difference or just good luck I don't know but I'm not rockin' the boat to save a few cents a gallon.
Mark's Garage est. 1983 Last edited by AlmostStock; 03-31-2005 at 09:20 AM. |
If you use Shell brand gasoline do you have problems with your fuel gauge reading improperly? Apparently there is an issue with Shell gas or the additives in it that are causing problems with the sending units in certain GM vehicles. I have a problem with my Venture van, and occasionally my Lesabre, but I do not have a problem with my C1500 pickup. I do not use Shell gas as there is no stations in my area, so I don't know if the gas has anything to do with it. You can check this link out for more info on the subject. http://www.automotiveforums.com/vbul...d.php?t=206543
Mark's Garage est. 1983 |
Thanks for all the replys...Im gonna change my air filter and spark plug wires tommorow...I noticed the car is only doing this when it is in drive or reverse...if its in park it idles fine..
