Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 03-30-2005, 12:03 PM
tipota tipota is offline
about to buy a 240: need some advice
what things should i be looking for? i found a 92 240sx for $2600. Im going to check the undercarriage for rust, and check the usual things like making sure the exhaust isnt blue, seeing if the engine makes clicking sounds, looking for oil leaks anywhere in the engine compartment. how can you tell if a car has a blown head gasket? i dont really hear of this being a problem on these cars, but its always good to check. also, is there anything else i should look at? im going to check it out in a few days wiht a friend so any advice would be much appreciated. thanx
Old 03-30-2005, 01:52 PM
nisco nisco is offline
Tib Guy
Send a message via AIM to nisco Send a message via MSN to nisco
Re: about to buy a 240: need some advice
is this going to be a project car or a dialy driver?
mialage, ask for teh past history of teh car, accidents/ recalls/ stuff liek that (if and why its been iin the shop)
see how the clutch feels (if its a 5speed)
body condition.. etc etc etc
almost that time
my sig made mommies cry, thats why i had to change it..
Old 03-30-2005, 02:12 PM
SHIFT_KA24DE's Avatar
SHIFT_KA24DE SHIFT_KA24DE is offline
if you want to play it safe check the car history... via VIN number. Also if there's oil/moisture near the top of the block then that means the head gasket needs replacement. Check for oil below the engine... if there is then most likey there is a leak somewhere or someone just doesn't know how to change engine oil/filter. I think what you mentioned about the exhaust fumes (blue/white) is good... also the ticking noise. If it's a 92 then most likely it WILL be ticking anyway... but don't worry about too much if it comes from the head area. (it's just the timing chain... you can later remove the guides to stop the ticking noise)
If you want to try price negotiating.. which i higly recommend. Try looking for brake rotor wear/warping, worn clutch, tire tread, interior/exterior damage, spare?, etc...
if it's a fastback... check the hatch for leaks because most likely it will be there. If it rained recently check the spare wheel well for moisture/water. You can knock off some $$ with that complaint as well. g luck. sounds like a pretty decent deal.
1993 RMS13 5MT KA
Old 03-30-2005, 05:09 PM
Hit_N_Run-player Hit_N_Run-player is offline
Send a message via AIM to Hit_N_Run-player
ask the seller if you can compression test it...
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Old 03-30-2005, 06:40 PM
Chuki_breath Chuki_breath is offline
yea i think all s13's tick, no matter what!!!!! Its like a 240 characteristic. Timing chain.
Old 03-30-2005, 09:22 PM
sidewayzS13's Avatar
sidewayzS13 sidewayzS13 is offline
doin it sidewayz
Send a message via AIM to sidewayzS13
i like the tick damnitt it adds character
Originally Posted by Muscletang
I say let it run its course. Most women experiment with things. They'll try something whether it's mind altering drugs, going down on their best friend, an Emo song, or plastic surgery.
Old 03-30-2005, 11:37 PM
yes.. it's almost like it's trying to communicate with me.... i know it.
1993 RMS13 5MT KA
Old 03-31-2005, 08:57 AM
shit! well what bad ticking versus good ticking? i bought an S13 about a month ago for $500, and i bought it as a project car. it had the ticking, but the ticking got louder as i brought the engine to higher rpm's and as i changed gears. the engine blew on the way home. the car only has 91k miles on it and the woman told me it has never been in an accident, but i havnt checked the VIN yet. i think i found the ideal situation. a woman driver who does not know the worth of the car and it selling it at book value. do S13's tick louder and faster as you rev the engine and switch to higher gears? I doubt the engine is going ot blow at 91k because the other one i bought had 167k on it. now as for the clutch, my friend taught me how to drive stick but ive never owned a stick car. how can you tell if a clutch is bad? also, thank you guys for all your help so far!
Old 03-31-2005, 11:50 AM
from a dead stop try and move starting with 2nd instead of first... if your clutch doesn't "catch" or you can feel it "slipping" that means your clutch is pretty worn out... replace it.
Other than that... check if you can do a small burnout... or actually just drop the clutch and see if your car jets forward w/ a lil' gas. these are all not-so-good ways but easy to check if your clutch is worn out.
1993 RMS13 5MT KA
Old 04-02-2005, 10:51 AM
im going to check the car tommorrow, so hopefully i can get a reply before then. about the ticking, does it get louder as you rev the engine and switch to higher gears, just as you rev the engine, or is it continuous?
