Old 03-30-2005, 11:20 AM
alharris alharris is offline
Question turn signals
i have no turn signals i think that it could be the flasher where would i find the flasher on a 03 blaxer or could this be somthing different. fuse are good.
Old 03-30-2005, 05:37 PM
Sen Sen's Avatar
Sen Sen Sen Sen is offline
Re: turn signals
Definitely try a new flasher..
and if it isn't you'll probably need to replace it in a little while anyways.
Mine goes every 3-4 months
94 Blazer S-10
1st Gen-4wd
4.3L W V6
Faster and louder than stock, but nonetheless a blazer!
Old 03-30-2005, 08:47 PM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: turn signals
the flasher is behind the glovebox. i've never seen one go bad. do the hazards work? do the signals work after the hazards are turned on? do the signals work if you bang on the steering column? if so the multi-function switch is probably the culprit
