Old 03-30-2005, 11:04 AM
Propagandhi41 Propagandhi41 is offline
Send a message via AIM to Propagandhi41
Problem - Fujimi 180sx back glass
i was painting the window trim on the back of the 180sx plastic and when i pulled off the masking tape it left BAD residue. i don't have any pictures though. when i saw it a panicked got some water and a towel and scrubbed to get it off...nope...then i though...rubbing alcohol....well..it smeared the residue and took off some of the paint which was the least of my problems.
i'm pretty sure it's ruined.
does anyone have any ideas of getting the plastic back to normal [i.e. removing the residue and paint] or does anyone know where i can order a new one or someone sell one to me?
i need help please.....
btw the model is Fujimi 180sx Type X
kevin.
Old 03-30-2005, 11:12 AM
KTem's Avatar
KTem KTem is offline
What paint did you use? Akrylic, enamel, laquer?
You should always do windows with acrylic paint since you can get it off just with water.
Old 03-30-2005, 11:16 AM
glacier985's Avatar
glacier985 glacier985 is offline
Send a message via AIM to glacier985 Send a message via MSN to glacier985 Send a message via Yahoo to glacier985
Re: Problem - Fujimi 180sx back glass
I had the same problem and used an adhesive remove and it worked like a charmed. No more residue is left.
1972 Datsun 240z, 45k, l28
1990 Nissan 240sx, 96k ka24eT
1994 Nissan Altima
1997 Nissan 240sx SE
Old 03-30-2005, 11:18 AM
tardster tardster is offline
Goo Gone, you can get it at ost stores, becareful though it will remove the paint if its not cured...
it wasn't the paint that messed up...it was the masking tape. thanks glacier985, i'll try that.
Old 03-30-2005, 02:57 PM
Amazon's Avatar
Amazon Amazon is offline
Household petrol takes away that kind of residue. The kind that`s left by stickers, tape e.t.c. Also maskingtape/Chromefoil residue.
Newsflash: Diecast sales fund terror activities.
Old 03-30-2005, 04:01 PM
Verminator's Avatar
Verminator Verminator is offline
Send a message via AIM to Verminator
Re: Re: Problem - Fujimi 180sx back glass
True, but you will also find it will make a big mess of your window. The best bet is non acetone based nailvarnish remover, if you use it sparingly it will have no effect on the clear part.
Old 03-31-2005, 03:59 AM
hawkone hawkone is offline
Send a message via AIM to hawkone
you could use methelated spirits just use a soft rag diped in some then wipe of residue
Old 03-31-2005, 07:59 AM
aN4rK1's Avatar
aN4rK1 aN4rK1 is offline
Oven cleaner, itll take off the paint and the residue, try that and u can start fresh
Old 04-16-2005, 09:28 PM
thanks guys...the goo gone worked perfectly...everything's back to normal i just have to repaint it
Old 04-16-2005, 09:47 PM
rotatox rotatox is offline
ive done that, works like a treat!!
Old 04-16-2005, 11:36 PM
Jaymes's Avatar
Jaymes Jaymes is offline
i've had the same problem with a Revell Camaro, except the Tamiya Maksing Tape seemed to have pulled off parts of the clear plastic. It wasn't residue...weird. So I had to sand it to even out the surface
