Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 03-30-2005, 07:53 AM
82 meeno 82 meeno is offline
3.1 has a couple of issues
I got my 3.1 installed, bolted down, wired up....
I turned the key to fire her and she just turned and turned and would not crank.
I definitely have fuel, and spark.
Could this be my crank sensor? I pulled mine off of the old motor before i took it to the junkyard, but, i didn't think to replace it until tonight.
I do rmember when i heard it run at the junkyard, it was having problems turning over initially but ran fine....
What is the difference between the crank sensor behind the block and the one on the harmonic balancer?
Also, the plug that goes into the bottom of the oil is not the same as the plug that i have leftover.... The color of the plug wire on the pan is purple/yellow; the one i have left over is looks like a brown/gray(could be wrong, its pretty faded and oily).
What does this oil pan plug do anyway?
I hope i wasn't too lengthly.
ANY HELP IS APPRECIATED, I NEED TO GET THIS CAR RUNNING!!!
