Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-30-2005, 01:38 AM
Chrisgys Chrisgys is offline
Eclipse GSX 99 Cold air intake
Hi everybody. I have an Eclipse GSX 99 and I would like to tune it up so I want to start with a cold air intake and I would like to now wich one ist the best. I was thinking about the AEM V2 but its written "for non turbo cars only" so I would like to get your suggestions thanks.
Old 03-30-2005, 02:10 AM
97_3clipse's Avatar
97_3clipse 97_3clipse is offline
Send a message via AIM to 97_3clipse
Re: Eclipse GSX 99 Cold air intake
if you want name brand, then injen is the only popular company that makes a intake for the 2g turbo dsm....
i would sugest the K&N fipk best bang for the buck....
1998 Eagle Talon TSi AWD
6 Bolt Swap \ DSMLink V2.5 \ ACT 2100 clutch \ PTE SCM 61 \ Forge MBC@28psi \ VPE O2 Housing \ MR Downpipe \ Thermal R&D Cat-Back \ Tial 38mm WG dumping off O2 \ FMIC w\ in short route \ AFPR setup/walbro 255hp \ PTE 880cc injectors \ Crower Ti retianers \ Crower Springs \ Crower 64414 (stage 3 race) cams \ Ferrea valves \ 3.5 bar MAP \ PLX M-300 Wideband
Old 03-30-2005, 05:47 AM
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
umm its called an innercooler no need for a true CAI
look for an injen intake for the turbo models, its not just a filter its the pipe too so its better than the FIPK
Something new is coming...
Old 03-30-2005, 12:16 PM
97_3clipse's Avatar
actually the stock intake tube with the dump tube cut flows just about as good as the injen metal pipe... no need to spend 200 dollars on that injen intake with the t25.... the FIPK is cheaper..
Old 03-30-2005, 01:54 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Re: Eclipse GSX 99 Cold air intake
Have you ever looked at the diameter of that accordian piece of shit? I agree, Injen is too expensive, but the stock intake pipe is no good. I paid $40 for a cheap filter/adapter and made an ABS intake pipe once, and this car I paid $60 shipped for a used ExtremePSI filter/adapter/pipe/couplers. Screw injen.
EDIT>> Cold air intakes are not a basic mod for turbo cars. In fact, nobody makes one. You might notice on track cars, they have expensive electronics so they can run a custom CAI, though.
Old 03-30-2005, 02:20 PM
97_3clipse's Avatar
Re: Re: Re: Eclipse GSX 99 Cold air intake
are you sure , people have been telling me that its almost the same.....
Old 03-30-2005, 05:56 PM
2of9 2of9 is offline
I'd agree with JoeWagon...unless you're paycheck is 1200 a week.
"i told you it was third, I lengthen the injector pulse another millisec and tuned the NOS timer, and you'll run nines"
--2OF9--
(DSM team specialist) ;D
#808/1000
Old 03-30-2005, 06:18 PM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
Even though the injen that replaces the stock intake tube is a LITTLE bigger, I highly doubt the difference would be much at all. The only way I'd buy a new intake pipe for stock turbo is if it were a 3" intake (just use reducer couplers to make it work). Not only would you be sure of better airflow, but you've got it covered if you ever upgrade to a turbo that has a 3" inlet.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 03-30-2005, 09:07 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
If ya want a good cheap intake.... take a looksee
http://www.posracing.net/HDintake.html
I made one and loved it... the sound of the turbo spoolin was way louder than the stock accordian piece of shit!!! I did end up "sellin out" and bought one off of ebay for pretty cheap and sounded the same... just looked better!!! lol
Here's an example of an ebay intake....
http://cgi.ebay.com/ebaymotors/ws/eB...category=38634
Don't know about the filter though... the K&N filter and mounting plate has a bigger opening than the one that comes with that ebay kit.....
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 03-31-2005, 10:44 PM
kjewer1 kjewer1 is offline
AF - Advisor
A 3" ABS intake on the 14b was worth 60 hz. But I have a feeling that RREs, or is it Dejons, lower 2.5 inch piece that you insert into the stock (but cut in half) intake pipe would provide the same gains on anything up to a 20g (with 2.5" inlet). For 3" inlet and larger turbos, a ABS intake works the tits. For 4" inlet turbos, you pretty much have to pay the big bucks for a real intake pipe. Might as well get a mean ass filter to go with it if you have a 4 inlet. http://www.posracing.net/bigmaf.html
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 04-01-2005, 03:22 AM
TreeFrog's Avatar
i'm still going injen, my paycheck is close to $1200 a week actually...
Old 04-01-2005, 02:16 PM
KevinE326 KevinE326 is offline
if thats what you make ur best bet is to get a gm maf with full 3" piping and get the k&N.
Old 04-01-2005, 03:25 PM
97_3clipse's Avatar
if you make that much what are you doing with a GS-T and a stock turbo?
Old 04-01-2005, 03:30 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Spreading incorrect information on message boards everywhere.
"innercooler"
"no need for true CAI"
Please. An i-n-t-e-r-c-o-o-l-e-r doesn't change the fact that colder, denser air makes more power. I have seen SEVERAL CAI setups with rubber couplers, ABS piping, and a 2g MAF out there...
Kris
2012 Genesis Coupe 2.0t
Old 04-01-2005, 03:42 PM
97_3clipse's Avatar
Re: Re: Re: Re: Eclipse GSX 99 Cold air intake
huh? how do you figure....
