Hey, all. The CE light on my '97 1500 5.9L came on last week and the code was for a #8 cylinder misfire. I changed the plugs and wires and air filter with a K&N filter. My question is should the CE light have gone off automatically or do I need to program it out? I don't mean to sound ignorant, but the light is still on and no other codes came up when the misfire was read. Any help would be appreciated.
DCDodge
You probably need to reset your pcm. To do so you have to disconnect your negative battery terminal and turn your key to start for about 20 seconds, let off, then reconnect your terminal. Code should be reset and light should go off. Hope this helps.
Re: 1997 1500 Check Engine light
Turn the key to start like I'm trying to start the engine, or just turn the key on for 20 seconds?
DCDodge
Turn the key like your starting your engine. All the way forward for 20 seconds. It's supposed to reset your pcm.
The PCM will gradually relearn as you drive anyway...that takes about 200 miles for a complete long-term learn.
Will doing this cause anything else to become screwed up with my engine or truck? It's running great and I don't want to risk causing more problems. Will the truck "relearn" anything the wrong way during the 200 miles that it takes to reprogram the pcm?
DCDodge
If you're concerned about battery disconnect......CE will reset itself after a given # of engine starts (after problem is corrected). My truck thru some misfire codes and needed some tuneup attention. Mines a 2001, and local Stealership tech told me over phone CE would reset after 100 "good starts". It actually took about 30.
I did it over the weekend and I've drove more than 200 miles and I have no problems.
