Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 03-29-2005, 11:16 PM
Canadenna Canadenna is offline
Won't start, flickering lights
I parked my car and when I tried to restart it 5 mintues later, all the dash lights starting flashing on and off and the ignition just clicked on and off. Now headlights, accessories, etc. nothing is getting power. Checked the battery it registers 12.7 volts, cleaned the battery connections. Nothing.
Old 03-29-2005, 11:35 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Won't start, flickering lights
I'm willing to bet you have a blown fusible link or a blown fuse. Check under your hood for the power distribution center and look for an 80 amp MAIN fuse, if that's blown that could cause your problems your having.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 03-30-2005, 10:56 AM
LMP's Avatar
LMP LMP is offline
CLean the battery connectors again..at both ends of cable. Then..what age is battery? This also sounds like a shorted cell. This happens regularly for 5-6 year old batteres and the result largely mimics corroded connectors. Testing 12v at battery with no load is meaningless. Test voltage on battery cable connectors with a load...and even when starting. Should not go below 10V.
Again, this is typical and classic "broken" battery supply.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
