Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 03-29-2005, 10:53 PM
Ziggymidget5 Ziggymidget5 is offline
Send a message via AIM to Ziggymidget5
Does it matter if camshaft company matches valve spring?
Would it make a difference if I ran Crower cams with high RPM (but not crower) dual aftermarket valve springs? Since the cams only contact the rocker arms, wouldn't everything be fine, atleast with a valve adjustment? Thanks for any help.
White 1995 Prelude Si 5-speed 107,000 miles
AEM CAI
AEM Pulleys
DC Sports CC Header
Carsound Hi-flow Cat
5Zigen Fireball Cat-back
17" wheels with 215/40/17 tires
Custom paint on some interior (yellow)
Currently in Progress:
KMS (Honda-performance.com) Camshafts, Valve springs, and Retainers
Skunk2 adjustable cam gears
Wish me luck on this project, something always seems to go wrong.
My 1995 Prelude Si
Old 04-01-2005, 10:50 AM
W-44Olds W-44Olds is offline
I would think it would be fine as long as those springs would handle the lift of your cam. I don't see why honda would be any different from any other engines I have built. You just need to make sure your springs are not too tight either. If they are they could eat the lobes right off the cam and if they are not strong enough you will drop a valve real quick.
Old 04-01-2005, 10:56 AM
Also the thing to remember is you can't go throw higher lift cams without higher lift springs,if that is what you are asking. Springs are rated by how much lift they can handle safely. So if you are upgrading to some BIG mofo cams you better get the right springs.Otherwise you will be out of a head and some pistons really quick.
Old 04-01-2005, 12:50 PM
Re: Does it matter if camshaft company matches valve spring?
Well I would think it would be alright cause I'm not doing anything drastic. Here are the springs I'm using http://honda-performance.com/info-lv2.asp?id=420&bhcp=1 and I'm using them with the stage 1 Crower cams http://crower.com/cat/import/honda/cams/h23.shtml
AEM CAI
AEM Pulleys
DC Sports CC Header
My 1995 Prelude Si
Old 04-01-2005, 01:07 PM
Gohan Ryu Gohan Ryu is offline
From the Crower website:
"Works with stock springs up to factory rev limiter"
So you should be fine - since the springs you will be using are stiffer than stock high revs should be no problem.
Old 04-01-2005, 01:23 PM
Alright, thanks. Just wanted to make sure I wasn't oblivious to something.
AEM CAI
AEM Pulleys
DC Sports CC Header
My 1995 Prelude Si
