| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
Hey everyone just had a quick question. I know that the 2g talon eclipse are suppose to run 12-14psi i believe stock. Does the stock BOV leak so much that it dosent reach those levels of boost. And will a aftermarket BOV help push at a higher level of boost.
Re: Stock BOV
The BOV's are said to leak at anything >15psi. Have you removed your BCS restrictor? If you are looking for a replacement BOV and don't need all of the "bling, bling"......just go with a 1g BOV. You can pick them up for about $40 and they will hold enough pressure to keep you busy for then next 2 years
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
Bcs
what is the bcs restrictor. Where is it, And what will removing it do.STEVE
Re: Stock BOV
Boost control solinoid.
http://www.freewebs.com/seanspage/BCS.html
Blowing motors since 2005. ![]() 1995 Eclipse GS 5 Speed(White) 1995 Eclipse GSX 5 Speed(Silver) Need a file hosted? IM me. For Sale:Fidanza Flywheel, 7 Bolt AWD $120 Will take trades too.Quote:
Re: Stock BOV
Mine only ran 9psi with the stock BOV. On a 1g it did 20+, so there's your leak. Get a boost gauge, every car is different. Don't spend $200 on a BOV expecting a big gain, since the max recommended boost on a stock t25 is only 16psi.
Re: Stock BOV
Get a 1gen BOV.... and then BURN THE 2GEN PLASTIC POS!!!!!!!!!! or sell it to some honduh low boost loser
.... or save it like I did.... that way when my car got totaled I was able to replace the 1gen bov with the stock one.. Now I don't have to hunt one down....again
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan |
Re: Stock BOV
2g bov's are jokes...seriously when i took it off to install my 1g bov i laughed. Get a UICP and a 1g bov cheap for like 150. David Brode UICP and used 1g.
Different people say different things about where the 2g leaks, but i have found that it is usually a small leak past 12 but will rarely hold more than 14. Uncrushed, the 1gbov can hold 18psi. |
