Old 03-29-2005, 10:29 PM
96jimmy4wd 96jimmy4wd is offline
egr mod???
do these work?? i cannot find any info on these except that it is a fitting, but i have an electronic egr does it go in the tube, or does it not fit mine??? are they worth it??
Old 03-29-2005, 10:38 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: egr mod???
i dont find it to be worth it
Old 03-29-2005, 11:10 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: egr mod???
Not worth it, no proven results whatsoever.
An engine will perform better and get better economy with a properly running EGR system.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-29-2005, 11:22 PM
Re: egr mod???
at most, if the egr system is giving you trouble, take it off and clean it
Old 03-30-2005, 06:16 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: egr mod???
No proven results??? Various dyno results during the initial creation of the mod have shown anywhere between a 4-9 hp increase, avg 1-3 mpg increase and more torque through the low to mid power band...If you want to see the dyno results from various trucks with and without the mod, contact OBIWAN at www.sicgmtrucks.com. (yes, the mod is useless at WOT)...
Old 03-30-2005, 03:26 PM
BlazerLT's Avatar
AF -Advisor
Re: egr mod???
I have searched the net high and low for proven results and there isn't any.
Old 03-30-2005, 06:53 PM
rlith's Avatar
Re: egr mod???
Again, simply go to www.sicgmtrucks.com and aski obiwan for the dyno slips.... Hell, GM themselves built the restriction into the system for the 2002+ motors..
Old 10-02-2005, 04:29 PM
SComp23 SComp23 is offline
Re: egr mod???
Could you possibly point me in the direction of how to do this mod and explain a but more about it? If there is a link somewhere that will suffice I tried to search but did not find much. Thanks rlith
Old 10-02-2005, 04:42 PM
Joshua M. Smith Joshua M. Smith is offline
Send a message via ICQ to Joshua M. Smith Send a message via Yahoo to Joshua M. Smith
Re: egr mod???
Hello,
We used to remove the EGR all the time on carbed motors and I have my '89 TBI EGR free as well. The EGR was originally an afterthought EC device.
Please remember however that the EGR lowers chamber temps. On a standard Chevy smallblock V8 the removal of the EGR valve puts the chamber pressures up from 2000deg F to 4000deg F.
I would not run this mod on anything with Al block, Al heads.
Josh <><
1989 Chevy/GMC "Blimmy," 4.3 motor, the only motor I've ever had that I've left stock
1993 Olds Bravada with the works.
My firearms board, in association with Hipowers and Handguns.com:Click Here
Old 10-03-2005, 05:51 AM
rlith's Avatar
Re: egr mod???
Certainly don't advocate BLOCKING off the EGR. This ends up being a fairly bad thing. Restricting the EGR is ok. As long as you restrict it to still allow 10% NOx you will still pass emissions without issue, and you have the added benifit of a better throttle response time off the line a better low to mid range torque. Slightly better gas miledge as well. It is usless at WOT, but the mod isn't done for that..
Old 10-04-2005, 11:01 AM
[RIT]IVIr_Evil's Avatar
[RIT]IVIr_Evil [RIT]IVIr_Evil is offline
Send a message via AIM to [RIT]IVIr_Evil Send a message via MSN to [RIT]IVIr_Evil
Re: egr mod???
Wot?
Old 10-04-2005, 11:45 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
WOT=wide open throttle.
EGR is used to reduce NOX by reducing combustion temps. This is done by introducing inert exhaust gas back into the combustion chamber.
One of the benefits of EGR is an increase in fuel mileage do to the fact that the inert exhaust gas displaces some of the air/fuel mixture…less air/fuel= better mileage.
The down fall of EGR is that the reduced presence of air/fuel means the engine has a decrease in power during off idle and cruising.
By reducing the amount of EGR, you can gain a small amount of horsepower.
The reason why the EGR mod does not work during WOT is because EGR is disabled during WOT events
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Booch Booch is offline
Re: Re: egr mod???
Originally Posted by [RIT]IVIr_Evil
Wot?
WOT = Wide Open Throttle
Old 10-04-2005, 02:05 PM
Re: egr mod???
Thanks for clarifying that up..
Old 10-04-2005, 07:33 PM
metallica21156's Avatar
metallica21156 metallica21156 is offline
Re: egr mod???
i remember reading some where that they tested it and that you gained power in the low to mid range but lost it at the high range. i did notice a inprovment in mpg with it. its off now. i had the hole to a 1/4" because 1/8 was to small.
95 jimmy. Vortec V6. 4.3 liter CPI. ,2.5" catco cat, 2.5" cat back with flowmaster muffler split rear., 40 street series, 2 12" audiobahns in custom box,K&N CPI intake system.
71 Mustang coupe- project car. stock 302 with Cobra intake, holley 650dp, afco racing radiator, headman headers, msd distributor, 2.5" from the headers.C4 tranny with shift kit, Mach 1 body lay out.
90 cav, 2.2 tbi, gas getter.
99 chevy s10 zr2, 6" lift, duel exhaust. 5 speed.
