Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 03-29-2005, 10:25 PM
K-Unit7 K-Unit7 is offline
Send a message via Yahoo to K-Unit7
Head Job car not starting!!!!
95neon.....SOHC. I Changed the head gasket, and After putting everything back in place, Car wont start sounds like theres no combustion like no kick in it. what could be my possibilities??? Thanks.
Old 03-30-2005, 09:45 AM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: Head Job car not starting!!!!
your cam timing has got to be off.
Old 03-30-2005, 06:56 PM
clydes1961 clydes1961 is offline
Had same problem initially with my daughter's '96 after replacing several valves following a broken timing belt at highway speed. The cam sprocket and crankshaft timing marks will align every two crankshaft revolutions so you are probably 180 degrees out. Align the marks and remove the timing belt then rotate the crankshaft one revolution until the marks are again aligned then replace the belt and you should be fine.
Old 04-02-2005, 08:41 PM
growe58 growe58 is offline
Um, I'm not an expert on this, but isn't this an interference engine and aren't you asking for trouble rotating the crankshaft while the cam (and the valves) are motionless?
Old 04-05-2005, 05:15 PM
Everything is moving, But but I do believe that my timing is off like what clyde said im like one revolutions off.
Old 04-14-2005, 11:10 AM
sweet_brandi_wines sweet_brandi_wines is offline
check out your crankshaft sensor first then your camshaft sensor these are often the cause. the only way of testing that is with an obd tester and even then it is posssible that no codes will show up. let me know what you come up with
Old 08-14-2005, 01:33 PM
g1smith's Avatar
g1smith g1smith is offline
Re: Re: Head Job car not starting!!!!
4 month old post . . . yea . . . I know.
A friend had the infamous blown head gasket on a '95 Neon SOHC. After replacing the gasked, we couldn't get it started . . . it would crank . . . we had injector pulses . . . spark . . . fuel pump priming and fuel pressure. Did a compression and leak-down test, and so it sat for about a year. Finally I decieded to give it another looksy and read a post that there is a power steering presure switch that feeds into the computer. I topped off the power steering fluid and it started for the first time in over a year!
Old 08-23-2005, 09:57 PM
deadBird's Avatar
deadBird deadBird is offline
...compression test
Old 08-24-2005, 07:24 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Originally Posted by deadBird
...compression test
I have heard of wierd things but topping off the P/S fluid and the car starts up. That's just crazy
Old 08-25-2005, 12:26 AM
yale329 yale329 is offline
I know it's not really nice to say, but I can't help it, you actually made a old man laugh. But really, HEAD JOB, CAR NOT STARTING. At 53 I can grin a bit.
From Wayne, hope you take this with a bit of humor.
Old 09-17-2005, 02:56 AM
g1smith's Avatar
The Dodge Neon is indeed a wierd animal! I can provide witnesses if you'd like on this one. The 95 neon sat for about a year, I think it was over a year until I read a post about a similar no-start problem. I topped off the P/S fluid just like the guy did in the post and about 10 of us who had worked on the thing couldn't believe it either. If you have a Neon of the 95 vintage, do you want to try and siphon out most of the P/S fluid and see it the car will start? Actually, my son-in-law encountered another no start problem on his neon last month. he had to thing for a while before rembering to top off the P/S fluid and it then started right up. I believe that it is beyond crazy. If it was my car, I'd drain the P/S fluid and try it. I've been a back-yard mechanic for a long time, and I've never seen anything like this! I can only guess that Daimler-Benz doesn't want to fix P/S pumps on warranty, so they built a circuit to disable the engine if it runs low on P/S fluid!
Old 09-17-2005, 11:23 AM
99 Neon R/T 99 Neon R/T is offline
Is it only on 95"s that the p/s problem occurs?Because I have a 99 and it leaks like a siv and I know I have started more than once with the p/s system being bone dry.
If it aint broke fix it till it is.
