Old 03-29-2005, 10:12 PM
84_camaro 84_camaro is offline
Send a message via ICQ to 84_camaro Send a message via MSN to 84_camaro
2.8L to 305 swap??
Hey, i have an 84 camaro with a 2.8L carbrated v6. I will be replacing it with a carbrated 305 h/o. Will i have to replace the wiring? will everything bolt up and will everything work right?
Chris
Bad pics of my car without my chrome rims.
Old 03-29-2005, 11:27 PM
whoisdabomb86 whoisdabomb86 is offline
Send a message via AIM to whoisdabomb86
AHEM......no everything will not bolt up, its gona be a bitch, u gotta mock in the motor drill holes (i welded my motor mounts in) theres always a ton of problems that need to be worked out, ull find out sooner or later, alls i can say is save up money cuz sh*t happens. 1 grand spent during my 2.8-350 swap, 3 grand spent b4 the swap, just on the motor parts mind u to do this. and it sucks, took me 5 days working 8 a.m-11 at night (long ass day) taking breaks here and there to eat. but i did a th350 swap on top of it, i did my whole interior, guages all over, shifter mounting, wiring. doing it clean takes a while. so just be patient man i know u can do it
Old 03-30-2005, 09:54 AM
The 305 i have is still mounted in the 81, well i have the front end of the frame with all the front end gear all the motor mounts, etc. So at least i have that to go by. The V6 needs a flywheel and starter, i found them but i need to get them off the car which would be a bitch because its sunk in the ground in the woods. If someone had a flywheel and starter for a good price i would use the v6 for awhile, but if not i have to start my swap.
Chris
Old 03-31-2005, 11:51 PM
i got a running 2.8 that i took outa my car, its urs for 100 bux, engine and tranny....i live in ct
Old 04-01-2005, 08:30 AM
That would be an awsome price if i didn't live in Nova Scotia .
Chris
Old 04-01-2005, 09:09 AM
Re: 2.8L to 305 swap??
oh man, the cars i was getting parts from got towed away, so now i have nothing. I reallt need a rear control arm or whatever its called from the rear end to the body on the drivers side.
Chris
Old 04-01-2005, 11:23 PM
Will you sell the flywheel and starter?
Chris
Old 04-10-2005, 11:05 PM
sry my dad kinda threw the motor out to bulky waste while i was at work, so its gone sry man
Old 04-10-2005, 11:07 PM
shitty......oh well.....i think i'm just gonna start the 305 swap.
Chris
Old 04-12-2005, 11:58 AM
stephenp stephenp is offline
Send a message via AIM to stephenp
i dropped a 350 into my 86 just bolted the motor mounts and dropped her in pulled the fuel pump and ran a wire out my fuse box to my distributer runs like a champ and the mounts mounted up
Old 04-12-2005, 10:12 PM
was yours a 2.8L? was it carb or fuel injection...whas the 350 carbrated? Also would it be easier to take the rad or front clip off when swapping engines, or just leave it all?
Chris
Old 04-16-2005, 05:26 PM
Green82z28's Avatar
Green82z28 Green82z28 is offline
Why not do a 350 swap instead of 305? 350's will produce more power and in some cases better fuel economy. you can find a 350 anywheres. thats what i would do.
Chevy guys always finish first!
Old 04-17-2005, 12:37 AM
because i already have the 305, it came with the car
Chris
Old 05-22-2005, 12:00 PM
I started taking the V6 out and noticed the 2 lines from the rad to the tranny i think. I don' have the 305 home yet, but does a turbo 350 tranny have the same set up as the 7004r? or will i need a different rad?
Chris
Old 06-10-2005, 11:34 PM
92EG6 92EG6 is offline
Noones probably listening but heres my opinion. I just put a carbed 350 inplace of a 2.8, first you dont have to weld anything, 82-92 camaros have holes drilled in the cross member for mostly any chevy engine. Take the motor mounts that are boltd to the xmember in your '81 out and bolt them to the xmember in the conv car, buy a chiltons it will show you what holes to use for v8's. Ditch the tranny cuz their shit. Do not run a TH400 unless you want to do some fabrication, TH350 will fit perfect use the driveline out of your '81 and buy the B&M torque arm adapter from summit, put the bracket on b4 tran goes in car, trust me. Stock shifter will work there is just no first gear, 2 is 1 3 is 2 and 4 is D/3rd get it. I just finished swapping a 350 from a 2.8. Email me if you have any questions. [email protected]
