Old 03-29-2005, 09:54 PM
rollenon18s rollenon18s is offline
Unhappy My amp is screwed
Got a problem...I have a mrd501 alpine amp, hooked up to two 10 inch types rs, My brother screwed around with my system and took out my suns, when they were pumpen fine...when i put my subs back in my car and connect everything the subs are not worken, i know the subs are not fried cause i hooked them up to my buddies amp...there is power to the amp, alll the wires are connected, there is no display of anything wrong wit the amp...any ideas on what could be wrong from you genius out there...
Old 03-29-2005, 10:05 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
Re: My amp is screwed
did you double check all fuses, power wire and on the amp?
Old 03-29-2005, 10:10 PM
yeah my power is good, and my fuses are not burnt
Old 03-29-2005, 10:15 PM
did you hook it up hot? (as in the power wire was connected to the batter?) and if you did, did you short out any connections to the chassis of the amp?.....
I don't claim to know anything, and I would wait for the knowledgble people to post (ng, sr20, bumpin) but I would say that your amp is screwed man....
Later
-Ryan
Old 03-31-2005, 11:15 AM
mysatilac's Avatar
mysatilac mysatilac is offline
pull your amp, place it in your buddies car, wire it up with his good setup, see if your amp is fried or fine. repost your findings
It's beautifully destructive isn't it,
'97 Maroon SL1- Bored Throttle Body, Knife Edged Throttle Plate, Short Ram Intake 3" Cone Filter, Flip Flop Trunk, Red Enameled Engine, Interior & Exterior Painting Mods, 4" Burnt Tip Muffler, DRLs ON A SWITCH!, "Rims", Seat Covers, And A Stereo System Thats Too Good!, Other various mods and detailing...
Old 03-31-2005, 11:36 AM
bjboertje's Avatar
bjboertje bjboertje is offline
i think your amp is fried
2001 Ford ZX-2
Alpine CDA-9855
SAX 100.4
Rainbow CMX 265 front stage
Stock 5X7 rear fill
Hifonics BX1505D
TC-5200
Old 03-31-2005, 03:08 PM
Hey thanks guys, it was a short, i tryed hooking it up to my buddies car and it didnt work ,so i got a sterio shop to open it and there was a short, so whenever i turned it on, the light would go on but nothign would happen, cause it was shutten itself down ,thanks guys, much appreciated for the advice.
