Old 03-29-2005, 08:33 PM
jt 71x jt 71x is offline
somthins wrong
aight, i was in my car and listening to my subs and they just shut off and i dont know what could have happened b/c the power light was still on ant the protection light was off and everything was hooked up right. they just shut off. i have only had them for a month.
Old 03-29-2005, 08:42 PM
Re: somthins wrong
is it possible i could have a fried amp
Old 03-29-2005, 08:44 PM
Diceman83's Avatar
Diceman83 Diceman83 is offline
Send a message via AIM to Diceman83
Re: somthins wrong
If there's not a failure or something in the head unit, subs or the amp, then the only thing left is wiring...
All I can say is:
-- check the signal leads to make sure they're still plugged in all the way
-- check the turn on lead, that tells the amp when the car is on
-- check the speaker wires for breaks or disconnects
You could try finding someone else with subs and trying yours with their set up and vise-versa. Without being able to see it, I can't tell you anything more than that.
Old 03-29-2005, 08:46 PM
Re: somthins wrong
thankz man
Old 03-29-2005, 10:18 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
Re: somthins wrong
When they stoped working, were you drivng and say, hit a big bump, pothole, something along those lines to jar a connection loose?...
Just wondering
-Ryan
Old 03-30-2005, 03:49 PM
Re: somthins wrong
no i was just listening to them befor work and then right befor i was going to go they just stoped working i wasent driving
