Old 03-29-2005, 07:00 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Fuse for power outlets?
I just bought a radar detector off a guy on 3SI, I plugged it into both my outlets but it didn't work. It does work in my moms car so I know that its not the detector. Does anyone know of a fuse diagram or where the fuse for the power/cigarette lighter things are?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 03-29-2005, 08:48 PM
unicyclemidget11 unicyclemidget11 is offline
here's the diagram
http://www.geocities.com/SiliconVall...an_fusebox.gif
same thing happend when i plugged my radar detector. turned out that both of my cigarette lighter sockets were bad.
Old 03-29-2005, 09:50 PM
Thourun's Avatar
Re: Fuse for power outlets?
Lol damn, how did you resolve it?
1995 3000GT VR-4
Old 03-29-2005, 10:35 PM
Thourun's Avatar
I went out and took the active areo/cruse controll/12v outlet thing out of the center console and it looked ok and clean (unlike the cigarette lighter on the near side of the stick... icky). the contacts looked good b there was no light, I think there is supposed ot be a little light lol. Any help people?
1995 3000GT VR-4
Old 03-29-2005, 10:36 PM
Stealthee's Avatar
Stealthee Stealthee is online now
Your worst nightmare
Re: Re: Fuse for power outlets?
Do your power mirrors work? If not then its the fuse.
Old 03-29-2005, 10:46 PM
Thourun's Avatar
They work, I checked the fuse just now and it looked fine. This realy sucks lol. I hope I don;t have to buy a whole new active areo/12v/cruse thing.
1995 3000GT VR-4
Old 03-31-2005, 12:09 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
well first try something else in the socket to make sure its not the radar detector if you haven't already. And then make sure both plugs are connected to the socket. If that checks out you might be able to buy an aftermarket socket, they're all universal, and you can probably take that cover right off yours and put it on a new one.
Old 03-31-2005, 12:11 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
pull off your shift boot and look under it, the plug may just be unhooked.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 03-31-2005, 05:00 PM
Thourun's Avatar
I tried that, both contacts look fine. Anyone know how I could diagnose this? I guess I could get a voltmeter but it seems like overkill.
1995 3000GT VR-4
Old 03-31-2005, 10:33 PM
voltmeters are like $5 and very usefull, so I dont see how that is overkill. If your being cheep just pull of a light from somewhere and run wires to it, if it lights up you have 12v.
Old 03-31-2005, 11:40 PM
Stealthee's Avatar
hehe, the cheap mans test light. I have a few of those lying around.
Old 03-31-2005, 11:45 PM
Thourun's Avatar
Lol if it blows out it has 12 volts, I didn't know they were that much, I thought they started at liek $30 or so. I guess thats the best way.
1995 3000GT VR-4
Old 04-01-2005, 12:17 AM
Stealthee's Avatar
No, if it lights up it measn the circuit has 12 volts. You can get a cheap analog voltmeter for less than $20 and they are good to have around for other things. I know I find handy uses for mine quite often,
