Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 03-29-2005, 06:23 PM
ahco ahco is offline
Please help: 1990 750 overheating. Suggestions?
Shortly after running our 750 it starts overheating. It does have enough water after we added water(but not antifreeze).
What suggestions do you have for starting to check the most common problems?
Thank you for help.
Old 03-29-2005, 07:15 PM
Antiburn's Avatar
Antiburn Antiburn is offline
Send a message via AIM to Antiburn
Re: Please help: 1990 750 overheating. Suggestions?
Water pump or thermostat most likely.
Old 04-01-2005, 02:57 AM
draleu draleu is offline
Does it overheat while idling or driving/
Old 04-08-2005, 02:37 PM
Re: Re: Please help: 1990 750 overheating. Suggestions?
Thank you for help. It seems to do it when driving. Actually it is confusing to me: we put in some antifreeze and car was running fine and not overheating the first time used and we thought that we solved it. The second time uded, within couple miles started overheating and went rpidly to the red line and had to be turned off.
May I ask: if we turn it on and let it just idle and it overheats: would that be a different problem?
Old 04-08-2005, 09:34 PM
Antiburn's Avatar
It would heat up at a much more slowly pace. It sounds like your water pump is bad. After about a mile its to hot to drive. Ide replace your thermostat as well.
