Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 03-29-2005, 11:23 AM
nick71nguyen nick71nguyen is offline
keyless entry reprogramming (car not starting)
I have followed the instructions in regards to reprogramming the keyless entry. After several tries, I was able to get the alarm keypad to lock & unlock the car. But when I used the key on the pad, the car would not start. The car would only start when I used the master key. Any ideas on fixing this problem? Any assistance would be very helpgul. thanx
Old 03-30-2005, 09:11 PM
boschmann boschmann is offline
Re: keyless entry reprogramming (car not starting)
The key needs to be programmed into the immobilizer system with a VW or VAG-COM scanner.
Old 03-31-2005, 03:59 PM
bjonpan bjonpan is offline
nick ... what instructions did you follow to program your key... i also have a new key and want to reprogram because old key is damaged... can i do this or do i need tool.. thx
Old 04-03-2005, 12:48 PM
Re: Re: keyless entry reprogramming (car not starting)
I tried both of these instructions, so I don't really know which one worked. Here they are:
1. Insert the master key into the ignition lock & switch on the ignition (do not turn on engine). Lock the vehicle from the outside manually using the second key. Press button a or button c on the remote control one time and then wait at least 2 seconds. Press either button once again one more time. Switch off the ignition and remove the key from the ignition lock. The manual programming procedure is complete.
2. Turn the ignition to the on, not start, on position. Put the other key in the drivers door lock. Turn the key in the foor to the right (lock position) and hold it for 10 secs. Then immediately turn it to the left all the way, & hold it for 10 secs. you should here a tone, or beep, like when the alarm arms. When you hear this press the unlock button on your remote. There should be another beep to let you know it has programmed. If you hear the confirmaion tone, take the key out of the ignition and see if the remote works now.
Hope this helps, good luck.
Old 04-03-2005, 12:50 PM
Basically this means that i would still have to go to the dealer and have them program it, right. Thanks for the response
Old 05-23-2005, 01:43 PM
point4zero point4zero is offline
Re: Re: Re: keyless entry reprogramming (car not starting)
FYI: I just bought a new remote and tried option 2 on my 98 GT and it did work. Thanks for the good information.
