Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-29-2005, 10:59 AM
solomontomb's Avatar
solomontomb solomontomb is offline
Send a message via Yahoo to solomontomb
Question lacking boost
hey guys i have a 1990 eagle talon awd turbo and im lacking boost. i can hear the turbo spooling so i dont think the turbo is a problem. i checked the intake wheel and it seems to be okay everything is intact. but i havent checked the exhaust wheel,will this prevent me from getting boost? or is their a lose hose somewhere? its a used car that i bought to let you guys know. it was building boost at 8psi,then it went down to 3psi what could be the problem..any help will be greatly appeciated. thank you
Old 03-29-2005, 03:06 PM
Urban_Squrill's Avatar
Urban_Squrill Urban_Squrill is offline
Send a message via AIM to Urban_Squrill Send a message via MSN to Urban_Squrill
Re: lacking boost
Boost leak.
Blowing motors since 2005.
1995 Eclipse GS 5 Speed(White)
1995 Eclipse GSX 5 Speed(Silver)
Need a file hosted? IM me.
For Sale:Fidanza Flywheel, 7 Bolt AWD $120 Will take trades too.
Originally Posted by EclipseRST
Thats like fucking glitter...
Old 03-29-2005, 03:29 PM
LouieAWDTSi's Avatar
LouieAWDTSi LouieAWDTSi is offline
MAJOR BOOST LEAK...my auto runs 11-12 psi..you should be right around that. Check everything that you possibly can. Search, there's a way you can make a boost leak tester for fairly cheap..think its on vfaq.com. Check manifold for cracks,hoses,etc. Good luck.
--the Cruiser-->97 Spyder GST 5sp ---3 inch exhaust, boost/vac gauge, mbc, greddy turbo timer, greddy fmic, greddy type S BOV, 17in wheels
--the DD-->99 ACURA 3.2 TL
--Sold 92TSi AWD, 6-bolt, auto, evo 3 gt turbo with supporting mods
Old 03-29-2005, 07:25 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Re: lacking boost
Definately a boost leak... well most likely... first thing to do is check ALL pipe connections from turbo to throttle body...
Here's the page for a boost leak tester... http://www.vfaq.com/mods/ICtester.html
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 04-02-2005, 04:57 AM
Whathits14 Whathits14 is offline
Re: lacking boost
Check for boost leaks from the turbo to the throttle, and also check all of your VAC hosing. Also, your exhaust wheel spins on the same shaft as the intake, so it is not because of the exhaust wheel.
