Old 03-29-2005, 10:26 AM
smokeymicpoter56 smokeymicpoter56 is offline
how hard is this to do for honda people?
im new to swapin engines in honda's. i have dun it on chevy and stuff but im going to try to put a d15b in my 90 civic dx and run it off a pr4 and a msd switch for the vtec and im going to have to wire up the mpfi and would like to know on 1 to 10 how hard every one thinks this is?
i have swap the same enigne before but there was really nothing to it.
oh and if any one has any sites that might help with any parts of this like msd switch to wire the vtec and wire the new mpfi?
do i have to change my disb or can i use my new disb from my d15b2?
can i use my alt from my d15b2 because i got a 150 amp one for that car and want'd to keep it the same?
and i was wanting to know if i forgot anything to worry about to?
Old 03-29-2005, 11:24 AM
91civicDXdude's Avatar
Re: how hard is this to do for honda people?
you will need to convert to MPFI and use those parts.
I will make a suggestion on the ECU and switch as well.. for less than the price of an MSD RPM switch ($65-$70), you could get a PM6 chipped to run 1 wire VTEC. It wont work with the PR4 though, so you'd have to absorb the cost of a 90-91 PM6 which would be about $50. so for $100 you can have a chipped ECU with proper maps to run your SOHC VTEC plus it controls VTEC... just something to think about..
Old 03-29-2005, 11:29 AM
Scott82 Scott82 is offline
I am putting that motor in my CRX right now, there is alot of info outthere on this swap, do some searches. This is my first honda swap too, i have put many motors in cars but i am converting to obd1 and havn't done that yet. I keep getting crossed up on wire color cause they all blend in together after awhile. But is you car currently Mpfi, if not you'll have to convert that, and also, i am pretty sure you want to use the dizzy that goes w/ the comp, for example, if you were running the p28 ecu then you would use the vtec dizzy on the motor, but since your using the pr4 then i am pretty sure you have to use the dizzy from the car w/ that comp. And also you will be able to upgrade to the si clutch kit from 92-95 as long as you use the same year flywheel, or you can just use you original stock too if you want, just make sure you change the flywheel from the recessed one to the flat one if you go that rout. I can't think of anything else off the top of my head but i am sure i missed something.
Old 03-29-2005, 12:59 PM
ok yes i have to do the mpfi swap and i dont have any money to change any thing i have to do it this way for right now.
Old 03-29-2005, 01:31 PM
what parts do i have to have to do this mpfi swap do i have to get a dif disb and what are some sites that show how to? i have been to 4genn and they really dont get in to if enough for me i want more info?
i need a full parets list im going to be usein the pr4 ecu can i use the 88-91 si setup on my d15b or do i ahve ot use its stuff?
Old 03-29-2005, 03:57 PM
some guy told me i ahve to ahve a 92 to 95 ex disb is this true or what whats some good sites for the mpfi i have been reading around all day i want to get this swap dun today. what fuel injector's should i use 88-91 or the ones that came wiht the d15b i have the little box for the 88-91 to thanks for all the help
Old 03-30-2005, 07:53 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
just do this http://www.thezcr.com/html/odbiconversion.php
everything you need to know right there.
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
