Old 03-29-2005, 10:05 AM
96silverado350 96silverado350 is offline
Send a message via AIM to 96silverado350
Daytime Running Lights
well im kinda glad i ran across this site. i was searching for a troubleshooting site and found this one, yall seem pretty helpful. but anywho, i have a 1996 Chevy Silverado and about 2 months ago my daytime running lights just stopped working. as you all know they are the same bulbs as the regular headlights without the oranges. my DRL's stopped workin but my headlight works fine when i turn them on. i know about the override switch, that dont work, and my parking break is not engaged, and i checked the fuse and it looks fine. what else could cause the problem... any suggestions?
Old 03-29-2005, 12:22 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Daytime Running Lights
There is a resistor that drops the voltage (around 8V, I think) so the DRLs aren't as bright as the regular headlights. It's possible that resistor burned open.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-29-2005, 02:15 PM
turborob turborob is offline
It was the DRL diode assembly on mine. Headlights worked fine, the DRL dash indicator light was on and all the fuses were fine. The diode is mounted to the steel rail under the dash slightly right of the steering column (looks like a little heat-sink with a wire connector attached). I got the part from GMpartsdirect and that took care of it.
Old 03-30-2005, 08:15 AM
yea i found what u were talkin about... do u know the exact name of the part so i can shop around... is it the diode, relay, or module?
Old 03-30-2005, 08:25 AM
I looked it up on gmpartsdirect.com and the 1996 seems to have a different listing than mine which is a 1997. On mine it was called the Diode assembly, but the parts listing for 1996 seems different and shows two parts.
I added what they call the DRL resistor to my cart and it called it a diode once it was in there. Part# 15043231 for $15.60. Seems very cheap compared to the part I needed.
The DRL module was part# 12088547 for $33.02. That seems more in line with the price of my 1997 Diode assembly, but I'm not sure what to make of it.
Old 03-30-2005, 08:37 AM
well i know its the same part ur talkin about... its under the dash, slightly to the right of the wheel, and looks like a heat sync... i need to see a picture of the part cuz i dont wana buy the wrong thing
Old 12-16-2005, 04:47 PM
pjdn pjdn is offline
I have just the opposite problem on my truck same year/model/350 vortex. The DRL's work but the headlights don't. So of course I also have no high beams. Could this be the diode part also or something else.
