up date on front end noise
Well I've taken the car to a front end specialist, We test drove the car
together,but he didn't reach to speed I wanted him to achived to feel the problem. He said it was just the tires,as far as he could detrimend it was not a bearing or a cv problem. Had the tires balance and rotated. When I drove the car home the viberation was more noticeable. Upon futher inspection I place my hands on top of the tire and I was able to more the tire back and forth and side to side.The tire on the otherside had no movement at all. I don't know if this is a mounting strut problem , or free play in the the cv or tie rod. I called the front end specialist and told him what I had found and it's back in the shop.
Re: up date on front end noise
Sounds to me that your front end specialist is more of a back end man. He should have jacked the car up and checked the front end components whether he felt a vibration or not. You could have a tie rod end problem or a ball joint problem that is causing your vibration. He should have checked in the first place!
