Go Back   Automotive Forums Car Chat > Mazda > MPV
Old 03-29-2005, 09:51 AM
ivorman ivorman is offline
Lightbulb 2004 MPV Hard Slam/Shift @ 20-30mph
Hi,
I have a newly acquired MPV that slams hard into gear between 20-30 mph, if you lightly touch the gas is doesn't happen, if you jump on the gas it doesn't happen. Only occurs on avgerage acceleration. I wanted to go to the dealer with info in hand so they don't balk. I have heard rumors of tranmission module reflashing.
ANY words of wisdom are appreciated...Thanks Kev
Old 03-30-2005, 02:55 PM
typesix typesix is offline
Re: 2004 MPV Hard Slam/Shift @ 20-30mph
Yes, it is a common problem and dealer can reprogram tranny with latest update to fix the problem.
Old 04-01-2005, 08:22 AM
Re: Re: 2004 MPV Hard Slam/Shift @ 20-30mph
Thanks
Old 05-02-2005, 04:49 PM
REcall in the midst
Went to the dealer today, and the service tech mentioned that a there is a recall to "re-flash the firmware" on the transmission module. Hopefully that will end the only problem we have encountered with this great little van......
Old 01-17-2006, 07:44 AM
Mike(nj) Mike(nj) is offline
Did the dealer fix the problem? Our 2001 at 61,000 is starting to shift harder under "normal" acceleration otherwise its fine.
Old 01-31-2006, 05:28 PM
rjitzsu rjitzsu is offline
there aren't any shift-related software reprograms for the 2001 mpv
Old 03-12-2008, 03:29 AM
nazouz nazouz is offline
I'm seeing similar problem with 2003. Any comment on the 2003 model?
