Old 03-29-2005, 06:16 AM
earp earp is offline
Passanger Side Power Window
Hey Guys.
The power window sunddenly stopped. Can't be controlled from none of the buttons.
I wonder, besides replacing the motor, if there's any electrical fuse or something like that that I should check before.
All other windows works properly.
Blazer 2000 4WD V6 Vortec.
Thansk friends..
Old 03-29-2005, 08:02 AM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Re: Passanger Side Power Window
Should tell you in the owners manual about the fuse box. In my 91 there is a big circuit that can be replaced that powers the doors. I would look in the fuse box first to make sure nothing is blown in there.
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 03-29-2005, 11:18 AM
Re: Re: Passanger Side Power Window
I did found a fuse in the fuse box that covers all four doors. but i woder if besides that I should check anything else?
thanks
Old 03-29-2005, 11:23 AM
was it good or blown?
Old 03-29-2005, 09:05 PM
96jimmy4wd 96jimmy4wd is offline
voltage goes from the fuse to the switches on the drivers side door including the lock switch from there power goes back through the door and to all of the other switches. check ohms accross the motor there should be less than 1 ohm, check for a break in the power wire going through the door. opening and closing the door will break the wires
Old 03-29-2005, 11:32 PM
DjEarth DjEarth is offline
This has happened to me a couple times on the drivers side.
It just stops..and then a day or two later..it starts working fine again?
Checked the fuses and they have been good. Don't know what else to do.
