Old 03-29-2005, 04:04 AM
sackerius's Avatar
sackerius sackerius is offline
Lowering Questions.
Alright me and a buddy worked on my car for looongg tonight..
its a 88 4door ..
we lowered 3 out of 4 corners...
the 4th one .. the bolts under neath just kept turning and turning to come off.. but wouldnt grab on anything.. making it so we couldnt get it GOING.. ya know?..
ok we got stuck on the bolt that the strut is attached to in the driver side rear....
there are 3 bolts total holding the strut in place... 2 in the trunk and 1 big mofo in the bottom, control arm or whatever......
we got the nut off of the inside end, but the screw is still in there and just wont come out....... it spins, and we have tried tapping it through the other side.. and nothing....
weve used impact, breaker bar, everything... and it spins and wont come OUT..
it makes no sense and its just frusterating.
it was really weird.
anyone know what I am talking about?? and any help??
THANKS!!
ALSO!!11
Me and a buddy did the coils on my car today...
now, when we did the rear (its a 88 civic 4 door)..
the middle of the shock has that protector on it to block the dirt/crap from going onto the bar that compresses...
we took off the protector because the coil wouldnt go down without it gone...
now from what I REMEMBER the shocks should still be good to go without that protector thingy .. right?
if not, we gotta jack it up and some how make a protector for them ....
any ideas???
right now they look like this
without the protector u can SEE the metal behind the coil
Vehicles I Currently Own
- 82 Toyota Tercel/Corolla (daily driver... o it kicks ass, lights the tires up real good hah)
- 88 Civic 4 door LX (not running, not sure what im going to do with it, race car, sell parts, sell?)
Vehicles I Have Previously Owned
1 - 85 Plymouth Caravelle
2 - 90 Civic Cx
3 - 83 Chevrolet S10
......And just for fun.... this makes me laugh every time.
image removed by moderator
Old 03-29-2005, 11:23 AM
1PhatCX's Avatar
1PhatCX 1PhatCX is offline
only thing i can think of is to heat it up, spray it with wd-40 and try to drive the fucker out with a hammer, it should just slide out.
we had this problem when we lowered my buddys 626, the one bottom bolt for the front wouldnt come out, so we tried taking the shock out anyways and when we moved it it broke loose and were able to tap it out
Old 03-29-2005, 11:39 AM
Scott82 Scott82 is offline
Re: Lowering Questions.
put the nut on the end of the bolt before yuu wack it too hard so you don't screw up the threads, and when it breaks loose you can take the nut off and you'll prob. be able to pull it the rest of the way out
Old 03-29-2005, 04:49 PM
PhReAzE PhReAzE is offline
Send a message via MSN to PhReAzE
happened on mine too, you can actually change the spring with that bolt still attached, the top should be able to lean out
Evan
Old 03-30-2005, 12:15 AM
Twyztidmind Twyztidmind is offline
Send a message via AIM to Twyztidmind
this happend to me on my 89 civic. Get a fork crow bar and put it on the screw get a hammer and hit the crow bar to your right. The screw should come out after messing with it for a while. It was a bastard to get out but i managed to get it out and not mess any threads up.
1989 civic DX with LS swap
94 B18B Engine
Stage III Six Puck Clutch
OBD-1 Conversion
OBX Altenater pulley
DC Sport Header
Tsudo 2.5" catback exhaust
Short throw shifter
Apexi Rev/Speed Meter
MUCH MORE TO COME!
1990 240sx w/ SR20DET SWAP COMING SOON!
All Brand new inteior
All body work is done
3" SR20Det downpipe
Apexi N1 Catback Exhaust 3"
3" Test pipe
Apexi Rev/speed meter
Old 03-30-2005, 08:05 PM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
mine didnt want to come out too easy...i just taped it out didnt take much of that...
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 03-31-2005, 03:55 AM
stang805's Avatar
stang805 stang805 is offline
Send a message via Yahoo to stang805
air hammers are always fun, might work too, i've had to use one a couple times
Old 03-31-2005, 06:09 AM
civic_geek133's Avatar
civic_geek133 civic_geek133 is offline
Send a message via AIM to civic_geek133 Send a message via Yahoo to civic_geek133
try jacking up the LCA a little bit to take some pressure off the bolt and then try to slide it out, thats what i had to do with mine and it came right out.
1989 Honda Civic Hatchback **RED**
FOR SALE
Civic: For Sale
Old 03-31-2005, 08:16 AM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
he he - mine was rusted - I ended up having to cut the forks off the strut. My bolt actually rusted to the metal bushing in the LCA.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
