Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 03-29-2005, 04:00 AM
Mee11 Mee11 is offline
TRD Supercharger
Just wondering if anyone knew how much one of the 1.8L Trd Superchargers would cost, Parts and Installation?
THX
Old 03-29-2005, 08:05 PM
LaYzIeNoY LaYzIeNoY is offline
Send a message via AIM to LaYzIeNoY
i'm not really sure but i don't think too many people could give you a price for parts as i think some will need to be custom made and fitted to your car
Old 03-29-2005, 08:12 PM
jmrev's Avatar
jmrev jmrev is offline
Re: TRD Supercharger
ive heard of a blitz supercharger costingabout 3000 or so...
Old 03-29-2005, 08:13 PM
hairbandmanx hairbandmanx is offline
I've seen them for around 2500 and up. But I asked toyota directly and they said it wouldn't fit a Celica or MR2 due to lack of space. They only recommend for use with the Corolla or Matrix. I'm sure if you had enough ingenuity you could get a hood or make a hood that would allow it but that's a lot of work.
If you want just Google something like Toyota 1.8L Supercharger or go on like Yahoo Shopping or something like that.
Hope this was useful!
Old 03-30-2005, 05:16 AM
I was just wondering because i saw this celica while i was looking around for trd parts and what not. I was just wondering if it was more or less of a bolt-on since it is a toyota product made for almost the same engine, 1zz...
here's that car http://www.toyota.com/motorsports/sp.../widebody.html
Old 03-30-2005, 11:43 AM
jmrev's Avatar
widebody celica:
SPECS SNAPSHOT:
TRD 1.8L (1ZZFE) SUPERCHARGER
Increases horsepower and torque up to 35%
Provides up to 7 ½ lbs. boost
Utilizes Eaton roots-type supercharger rotating components in an integrally cast housing assembly
Supplemental TRD ECU provides recalibrated engine management for optimum Supercharger performance
Old 03-30-2005, 11:56 AM
tfeld tfeld is offline
As already noted above, the problem with the TRD supercharger for the 1ZZ in the Celica is a fitment issue. If you could manage to fit it in there, it would no doubt work fine, however, as with the MR2 Sypder guys, there's just no room to poke a S/C without extensive modification to the firewall (in the case of the Sypder).
It is a bolt-on unit. I put one on my Land Cruiser (obviously a larger Eaton unit, but made the same). You have to swap out the crank pulley which is the most difficult thing (304 ft-lb torque!), but otherwise is a straightforward install which takes about a day or long afternoon.
The cost on the LC version was $2750 a few years ago. If you do the work, then there really no additional cost. If it could be done, the dealer would want a lot to do this however (est. about 10 hrs labor).
