Old 03-29-2005, 01:41 AM
redlineclipse redlineclipse is offline
Wheels
would 18's fit on a 96 eclipse without having problems rubbing?? it's not lowered or anything. but if it would be a hassle to have 18's I'll just go for something smaller. How bad would 18's offset the speedometer?
Thanks
Jason
Old 03-29-2005, 08:55 AM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: Wheels
Yes they will fit. I don't know what the offset will be. But if you dont lower it, I think it will look dorky, especially with the 18's on there, but its up to you.
good luck.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 03-29-2005, 01:04 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
18's with a 40 profile tire look very nice on an eclipse, even without being lowered. i don't think that it offsets the speedometer much at all, maybe 1 mph or something and you would have no trouble with rubbing. the 18" rim has nothing to do with rubbing, it's the size of the tire that you put on.
1" bigger/smaller diamater tire is about 3-4 mph off. therefore 1" bigger, you would be going 3-4 mph faster than the speedo says and 1" smaller and you're actually going 3-4 mph slower than the speedo says.
95 Talon TSI AWD
97 Eclipse GST
Old 03-29-2005, 02:48 PM
Gsx_hooptie Gsx_hooptie is offline
Re: Wheels
If you want 18's, 40 profile will be the way to keep your spedo as accurate as possible (within fractions of a percentage point, since you have a 96 which I think only came with 16's). Lower the car, why not. Whether or not it'll look silly without being lowered, it's sure to look better if it is.
I agree. You might get away with 235's, but if you want to be safe get 225's or smaller. It also depends on rim width. For more info go here: http://dsmtuner.com/forums/showthread.php?t=97471
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
