Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 03-29-2005, 12:55 AM
Denit Denit is offline
Unhappy Help! 1998 Jeep wrangler is missing.
Hi, I have a 1998 jeep wrangler and I need your help in solving a problem! I recently took it to a machanic because it was missing and backfiring badly. He changed all the wires, plugs, rotor, and distributor cap but it didn't help, it's still doing the same thing. It doesn't seem to matter if its a damp or dry day, and once it acts up and sits for a while it seems to run fine again. I'd appreciate any suggestions? Thanks a bunch!
Old 03-29-2005, 07:57 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Help! 1998 Jeep wrangler is missing.
Maybe crank position sensor or camshaft position sensor? It's a 4.0 Liter, right?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 03-29-2005, 12:26 PM
GreenJeep10's Avatar
GreenJeep10 GreenJeep10 is offline
I agree with Jackson. I haven't had this problem with my Jeep but I did have the exact same problems with a 91 Grand Am. I would definately check out the crank shaft sensor. With the Grand Am it would run fine for several miles and then just die. If I started it up right away it would run for several more miles and then die again. If I let it set after driving 10- 15 minutes it wouldn't start. Had to let it set at least 3-4 hours before it would start and sometimes several hours were required. I sank alot of money into new computer and had it at 4 yes 4 mechanics and on various computers and they couldn't find the problem. I hope this helps. Good Luck.
Old 04-05-2005, 12:28 PM
myjeepsux420 myjeepsux420 is offline
Send a message via MSN to myjeepsux420
I had a similar problem on my 1995. I replaced the crank sensor because everyone has had problems with them, but it turned out to be a bad fuel pump relay. I found a small crack on the side of the relay and found the inside to be corroded. I haven't had a problem since
