Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 03-28-2005, 11:59 PM
GQ_LS GQ_LS is offline
Angry How the hell does this happen?
Can anybody tell me how in the HELL does this happen? How does a battery go from 12V to 1V when they "claim" everything was turned off.
REPARK
1/13/2005 1:16:25 PMMOVE CAR1/13/2005BATTERY CHECK1/13/200512.0 VOLTSCHECK FOR LEAKS1/13/2005TIRE PRESSURE CHECK1/13/2005ALL FLUID LEVEL CHECK1/13/2005OIL DARK BROWNENGINE RUN, A/C & HEAT1/13/2005CHCK LIGHTS, GUAGES, HORN1/13/2005ENGINE COOLANT CHECK (RESV. ONLY)1/13/2005-40
MOVE CAR 2/22/2005BATTERY CHECK2/22/2005BATTERY DEAD / WILL STARTCHECK FOR LEAKS2/22/2005TIRE PRESSURE CHECK2/22/2005ALL FLUID LEVEL CHECK2/22/2005OK / NO CHANGEENGINE RUN, A/C & HEAT2/22/2005CHCK LIGHTS, GUAGES, HORN2/22/2005ENGINE COOLANT CHECK (RESV. ONLY)2/22/2005
MOVE CAR 3/11/2005BATTERY CHECK3/11/2005DEAD/1.0 VOLTSCHECK FOR LEAKS3/11/2005TIRE PRESSURE CHECK3/11/2005ALL FLUID LEVEL CHECK3/11/2005OIL BROWNENGINE RUN, A/C & HEAT3/11/2005CHCK LIGHTS, GUAGES, HORN3/11/2005ENGINE COOLANT CHECK (RESV. ONLY)3/11/2005-10
"Many people go their whole lives wondering if they made a difference, Marines don't have that problem."
President Ronald Reagan
Old 03-29-2005, 02:41 AM
OldRelayer OldRelayer is offline
I don't know how it happens, but I can tell you it isn't unusual. I worked for a Lincoln dealership. If we had an LS in the showroom for any length of time, a couple of weeks, the battery would be dead. This is also true of the Thunderbird, which is basically the same car with different sheetmetal. I don't know if that was rectified in the newer models, I know they made some major changes in 2003, this problem may have gone a way. You might consider investing $20 in a trickel charger and just leave it on when your not going to be using the car for a while. Ford batteries are also suspect. We would loose about 10% of them over a winter, I guess it has something to do with them not getting fully charged, because they were always being moved 10 feet and shut off. When this happens Ford won't pay for a new battery, the dealer has to eat the cost of a new battery.
Old 04-04-2005, 12:07 PM
CGGorman's Avatar
CGGorman CGGorman is offline
Re: How the hell does this happen?
What are the details on the car and ANY aftermarket accessories?
Chris Gorman -LLSOC Forum Moderator-
2000 LS8 sport (lowered 2", LLSOC Intake, Magnaflow catback, tint, more..)
Old 04-04-2005, 05:41 PM
Re: Re: How the hell does this happen?
I own a 2000 V-8 Ultimate. At the moment the only aftermarket items include upgraded brakes ad rotors, cold air intake, went down an inch with Eibach springs and that's about it for now. It's been in storage since June of last year. The battery was two days old when I delivered the car to the storage place. As far as accesories, I don't have any aftermarket ones that would drain the battery, all the electronics are stock.
Old 04-05-2005, 10:17 AM
CGGorman's Avatar
My first idea was an aftermarket or improperly installed factory alarm/remote start which were notorious for draining batteries. Some trailer harnesses have caused problems, as well.
This will be difficult to impossible to track down.
Good luck.
