Old 03-28-2005, 11:03 PM
MIBlazer98 MIBlazer98 is offline
Driver side brake noises
I have a 4D 2WD 98 Blazer with 64K miles. The front drivers side brake makes a cruuck cruuck cruuck noise that slows as I come to a stop and is usually only audible about 15 feet prior to coming to a stop until I stop. This noise only happens when the brakes are being applied and is distinctly coming from the drivers side. Before Lt suggests it... Yes I've grease all Zerks and All have accepted about two pumps of grease. The pads have about 1/3 of their life left but this noise has been happening for about six months or so and is bugging the ever lovin ^%$# out of me. Any suggestions? Could this be a rotor issue... or would it most likely be the pads moving funny. If it helps, it seems like I get slightly excessive noise from the front brakes when backing and the brakes are releasing.
Old 03-28-2005, 11:10 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Driver side brake noises
If you are say travelling 40-50mph and your press the brakes moderately, does the truck shake at all?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 03-28-2005, 11:37 PM
no not at all.
on a side note..just replaced the idler arm thanks to this site...steering and center feel is much better..saved big time$$
Old 03-28-2005, 11:50 PM
BlazerLT's Avatar
AF -Advisor
More than likely your pads are worn out and you are riding the indicators.
Old 03-29-2005, 09:13 AM
this is not the case..indicators aren't near touching the rotor
Old 03-29-2005, 10:58 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
^how do you know? did you check all 4 pads or just took off the wheel looked at one outside one? if thats the case you need to get a look at all 4 pads in the front...
Old 03-29-2005, 12:34 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Driver side brake noises
If the noise does not go away when braking, you might have to check out your dust shields to make sure they aren't making contact and to check your CV joint boot on that side for cracks.
Old 03-29-2005, 03:57 PM
I checked out all four pads in front... I wouldn't post unless I was stumped after checking the simple stuff. I'll recheck the dust sheild but didn't recall any issues there. I wonder if the rotor is warped funny and causes the caliper to flex when the brake is applied??? Could this fexing cause the noise?
Old 03-29-2005, 03:58 PM
2wd
Old 03-29-2005, 07:18 PM
BlazerLT's Avatar
AF -Advisor
Did you find any play in the front bearings?
Old 03-29-2005, 07:47 PM
ricksza's Avatar
ricksza ricksza is offline
Check the edges of the pads where they contact the sliders. A light coating of silicone grease may resolve the noise..
