Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 03-28-2005, 11:02 PM
jonny2006cchs jonny2006cchs is offline
Question CD Changer
I jus bought a OEM cd changer for my 01' jetta, and it supposedly works fine. but I hooked it up and it still said there was no changer connected.. Is there anything i need to do before being able to play?
Old 03-28-2005, 11:06 PM
bigblackone bigblackone is offline
Re: CD Changer
go back and look at it again ... when you look in there realize that there is a blank connector in the car that you need to remove before you can connect the changer to the actual connector ... its a little stiff to get off, but you will know what I mean when you get it off...
Old 03-29-2005, 02:37 PM
I went and looked for a blank connector on either end of the hook ups and I didn't find any, and they connect together, so i don't know... I did find that the hook up in my trunk has 9 pins, yet the cd changer has 10. Not sure if that'd play a factor in it.
Old 03-29-2005, 05:34 PM
Re: CD Changer
are you sure the hookup in your trunk is the actual hookup? on mine it was a blank "cap" type thing that covered the actual connector ... I removed this "cap" (which happens to look like an actual connector) and was then able to connect my cd changer.
Old 03-29-2005, 06:39 PM
Yeah, i'm pretty sure. there are wires runnin to the connector in the little hidden spot on the side. i jus figured that the owner before me sold it, b/c i thought all monsoon stereos had the cd changer.
Old 03-29-2005, 06:41 PM
Re: CD Changer
oh, when i look at it...if i were to take out the black cover over the pins then it wouldn't stay connected to the changer.
Old 03-30-2005, 09:06 PM
boschmann boschmann is offline
Re: CD Changer
You need to go inwith a VAG-COM or VW scanner & reprogram the radio to know trhere is now a CD attached.
