Old 03-28-2005, 10:34 PM
shoctrtmnt shoctrtmnt is offline
2001 3.5 intrigue oil filter changing
ok so today i tried to change my oil filter, i usually take it to jiffy lube, anyways i cant figure out how to get to the oil filter can someone help me out here....
thanks
rich
Old 03-29-2005, 12:34 AM
kimbo99 kimbo99 is offline
I use a Flotool #4 Super Graphite filter wrench purchased at my local auto parts store (Kragen) for $6, works great, attaches to a 3/8” drive ratchet. Pennzoil makes a similar metal filter wrench. I assume it is also #4 size (which would make it p/n 19804).
FYI, you can remove the filter without draining the oil first. Also, factory spec for oil filter tightening is 18 ft-lb, and oil drain plug is 15 ft-lb.
Old 03-29-2005, 03:24 PM
Burnout524 Burnout524 is offline
Re: 2001 3.5 intrigue oil filter changing
Yeah, that's a great attachment to have; we've got one for the Intrepid.
I wish the Olds dealer knew those torque ratings; the last time my oil was done, I had to get a new drain plug since the mechanic tightened it so much that it stripped the threads on the plug.
'99 Olds Intrigue GX
Old 04-24-2005, 09:09 AM
kmohr3's Avatar
kmohr3 kmohr3 is offline
Send a message via AIM to kmohr3
I know what you mean, I have a major trust issue letting anyone work on my cars. I went out and bought a new inch/lb torque wrench for working on my aluminum 3.5L engine. I torque everything, including the oil pan drain plug and filter. By the way, my car had the improper drain plug in it. The proper one from GM (88891787), has a recess under the head of the bolt to accomodate the rubber seal (3536966).
I bought the GM filter wrench (Kent-Moore J-29142) or SPX is the name on the invoice. Let me know if you want the phone numbers to place an order.
Old 11-07-2005, 02:43 PM
Dan "The Man" Dan "The Man" is offline
Can't Find the Oil Filter
It sounds like you know where to find the oil filter on the Intrigue (I have a 2000 V6)...can you help be locate it? Thanks!
Old 11-07-2005, 08:51 PM
kmohr3's Avatar
on the 3.5 liter it is a cartridge type filter and is in the oil pan. The cover for it is on the bottom of the engine oil pan
