Caravan 3.3L brake booster pump keeps coming on ...
Hallo all,
Has anyone come accross this issue .... 1992 Dodge Caravan 3.3L the brake (booster) pump comes on and buzzez for 20 seconds, switches off for about 30 seconds then comes on again. It keeps on doing it all the time over and over. |
Re: Caravan 3.3L brake booster pump keeps coming on ...
I don't think that's the booster you're describing, sounds like your ABS pump is acting up, I'd try locating the pump and disconnecting it and see what happens.
Daily Overhauls Do Get Expensive Dangerous On Days Gears Engage Dead On Day Guarantee Expires Dead Or Dying Gas Eater Department Of Defense Garbage Equipment Dodge Owners Don't Get Excited Don't Overdrive Gutless Engine Drips Oil Drops Grease Everywhere 1995 Dodge Dakota SLT 3.9 V6 1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4 |
Re: Re: Caravan 3.3L brake booster pump keeps coming on ...
Thanks Sam |
does your brake pedal pulsate when you try to stop?
If I'm not mistaken, all the booster does is apply engine manifold vacuum and atmospheric pressure to make the brake pedal not as hard to apply. Ususally, if a booster goes bad, you'll notice the pedal going rock hard (if I'm understanding you correctly by what you meant in your last post) or a drastic fluctuation in the engine RPM when you hit the brakes. The booster doesn't pressurize the brake fluid, the ABS pump, yes that will increase brake fluid pressure.
