Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-28-2005, 08:57 PM
supergoat's Avatar
supergoat supergoat is offline
95 V-10 transmision problem
I Have A 1995 Dodge Ram 2500 4x4 Truck With A V-10 If I Let It Sit For A While And Crank It Up It Will Not Go Into Reverse Untill You Rib It Up. Then It Slams Into Gear, And When You Take Off In Drive After It Sits It Will Only Shift Into Second Gear But If I Get It About 3000 Rpms And Let Off The Gas It Will Shift. After It Shifts Out One Time It Shifts Perfect The Whole Time Im Driving. Does Anyone Know If This Is A Simple Problem To Fix Or Do I Need A Rebuild.
Old 03-30-2005, 12:08 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 95 V-10 transmision problem
have you checked your fluid level and color? If your fluid is even a pint low, it could cause cavatation and delayed shifts b/c it has to take a while to build up pressure.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 03-30-2005, 06:59 PM
supergoat's Avatar
Re: Re: 95 V-10 transmision problem
I have changed the fluid and filter. The fluid that came out of the tranny was clean and their wasn't any metal in the pan. I checked the fluid level while running in neutral and it shows to be full.
Old 04-04-2005, 10:08 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
How many miles? If there's a dirty passage or gunked up spring/check ball in the transmission IMO it could cause the problem you're experiencing. Next time you have it opened up, you may want to remove the valve body and clean it thoroughly. Good time to install a shift kit too, if you've got a lot of miles on it.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 04-05-2005, 09:22 PM
supergoat's Avatar
The truck has 116,000 miles, that could be some of the problem.It has sat up for about the last year and drove only a few miles a month. What could i put in the tranny to maybe soften the seals and unstick any valves?
Old 04-07-2005, 08:11 AM
Yeah; letting a high mileage vehicle sit is oftentimes bad news. There are numerous transmission flush products out there, and removing the valve body and cleaning it can't hurt either. You've already changed the fluid so that wasn't the problem.
