Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 03-28-2005, 08:30 PM
93-240SX-COUPE 93-240SX-COUPE is offline
Send a message via Yahoo to 93-240SX-COUPE
When an engine gets old, what gets old?
I know this sounds dumb but Im not a mechanic. I know you can buy new internals like pistons, rods, bearings, etc. but what gets old and used up when you say "My engine is old". Are you just reffering to the pistons, rods, etc. or what exactly.
Old 03-28-2005, 08:41 PM
S14.Blacktop's Avatar
S14.Blacktop S14.Blacktop is offline
Send a message via AIM to S14.Blacktop
Re: When an engine gets old, what gets old?
usually you are reffering to the piston rings, also the cams and injectors can start to die out. Pistons and the crankshaft are usually signs of more serious problems like blown head gaskets.
I own a Blacktop SR20DET!
Old 03-28-2005, 09:33 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Friction exists everywhere. If it didn't then nothign would ever quit moving. The law of inertia states that an object remains in constant motion until something stops it.
What wears out is a long list. Every moving part develops larger and larger clearances. If the engine wears from only age, then typically rings wear, rod and main bearings wear, ect ect. Want proof? Look at your oil. Now I'm gonna give you a hint on this one. Oil doesn't wear out. It gets contaminated. Now assuming your PCV system is working correctly, what makes the oil darker over time? metal particles. Thats wear. Obviously some is blowby, but darker oil quicker will also mean more blowby hence wear.
Best way to determine engine condition is to do a compression test or a leak-down test.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 03-28-2005, 11:14 PM
TatII TatII is offline
dark oil can mean oil is getting burnt. for some weird reason my car has been gettin black oil every since the day i bought it. i would burn 1 qt of oil every 3000 miles but i still have perfection compression. i would change my oil then drive for 100 miles and the oil would turn black for some reason. its gettin burned somewhere really slowly and i don't from where, but when i switched over to syntec the dark oil would now take like 500 miles to get.
now for the things that wears out. usually the seals, the bearings, the cylinder walls, valve seats, the valve guides, and the rings are usual wear items. for the 240sx KA's we also have to worry about our timing chain stretching and the nylon valve guides breaking over time.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 03-29-2005, 12:15 AM
240SX Guy
Tat, you mentioned you couldn't get to your PCV valve. May be time to change it. I know mine needs to be done.
-Cory
12.6@122mph
Old 03-29-2005, 12:40 AM
mynismo mynismo is offline
yada yada yada
Send a message via AIM to mynismo
i'd say bearings or rings eventually go. everything has a life span.
438whp / 373tq - 11.9 @ 126
Old 03-29-2005, 07:45 PM
Soooo true mynismo...soo true, thats what a lot of people never think of, everything can only last so long until it dies down.
Old 03-29-2005, 08:19 PM
LaYzIeNoY LaYzIeNoY is offline
Send a message via AIM to LaYzIeNoY
fluids
gaskets can be a problem
rings
bearings
valve seats
cams
blets
timing chain
the cylinder walls can get warpped
water pump
oil pump
for the most part under basic repairs and normal driving no races etc., the pistons, rods, crank shouldn't recieve to much damage
an old engine is basically cuased by friction, the motion of engine parts cna cause the points of contact to be shaved down over time cutting away at them, then the shaving move throughout the engine and can lead to damge else where, [like sand erroding rocks]
Old 03-29-2005, 09:09 PM
240SX Guy
Just so happens nissan engines last forever when maintained.
-Cory
12.6@122mph
