Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 03-28-2005, 08:54 PM
95 clipse 95 clipse is offline
95 eclipse spewing oil
I'm new at this. I just bought a 95 eclipse nonturbo. There was oil in the spark plug tube so I replaced the valve cover gasket, plugs, and wires. I changed the oil and filter. When I started it up it ran rough at idle and oil was leaking from the tail pipe. Am I going to need a new motor and if so where could I find a decently priced one?
Old 03-30-2005, 03:54 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Re: 95 eclipse spewing oil
did you replaced the spark plug oil seals?
you might have bad piston rings. have you done a compression check?
DSM geek
