Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 03-28-2005, 07:29 PM
S14.Blacktop's Avatar
S14.Blacktop S14.Blacktop is offline
Send a message via AIM to S14.Blacktop
Thought I should throw this out there...
in my sig it shows how much money i have in buying the s14 sr20det engine swap for my 93 240sx, I was wondering what you guys think of the s14 swap and if it is really worth the extra grand. I did some research on google but now im stumped as to what I should do.
I own a Blacktop SR20DET!
Old 03-28-2005, 07:41 PM
logik23's Avatar
logik23 logik23 is offline
Banned
Send a message via MSN to logik23
Re: Thought I should throw this out there...
You get the VVL and like 10 extra horses and might get lower kms, if you go with an upgraded turbo, you might as well go with the S13 blacktop, same miles as the notchtop, but without the VVL which I've heard isn't all that needed when tuning.
Old 03-28-2005, 07:46 PM
Hmmmm...intresting...Logik, you seem to know a shit load about 240's and the aftermarket, But then again i geuss thats what research and this place does to you, maybe i might get off my lazy ass and go do some research instead of asking you guys always.
Old 03-28-2005, 09:34 PM
Tims_240's Avatar
Tims_240 Tims_240 is offline
and you'd definitely be surprised at how easy engine swapping is. im not saying that it isnt hard, and ive personally have never done an SR swap, but i just swapped a civic hathbacks stock motor, for a D15, just me and a friend and an engine hoist, and it took us about 6 hrs, i never really knew that i knew so much about cars , we have it running and moving (long story), but everytime we rev it up it bogs down past 3.5k.... o well, i hope im giving you some motivation to do it.
mods list: t3/t04e, iap oil lines, iap i-c piping, xspower i-c, z32 mafs, enthalpy tuned ecu, 615cc injectors, s14 tomei fuel pump, blitz DD bov, tial 38mm w/g, BD exhuast mani./downpipe, Spec StageIII clutch .
.s13 power.
power estimate at ~ 270 whp @ 11 psi.
Old 03-28-2005, 09:37 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Swap is easy, wiring seems like a little bit of a hassle. We need your goals before we can compose an adequite decision.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
Old 03-28-2005, 10:35 PM
Hit_N_Run-player Hit_N_Run-player is offline
Send a message via AIM to Hit_N_Run-player
you should always set your self a goal when tuning or modding, it helps...
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Old 03-28-2005, 10:41 PM
sidewayzS13's Avatar
sidewayzS13 sidewayzS13 is offline
doin it sidewayz
Send a message via AIM to sidewayzS13
r u sayin like set a HP goal or like a money spent goal ect.......?
Originally Posted by Muscletang
I say let it run its course. Most women experiment with things. They'll try something whether it's mind altering drugs, going down on their best friend, an Emo song, or plastic surgery.
Old 03-28-2005, 10:53 PM
a HP goal would probably be best, that way you know how much HP your wanting from the car your building...
1988 conquest TSI
Torque wins races!
Old 03-28-2005, 11:20 PM
TatII TatII is offline
the S14 SR20DET have a different head, and has a VVT system. the main reason why i would get a S14 is for that variable cam timing system. also if your not planning to upgrade the turbo anytime soon, the S14 SR comes with a larger T28 turbo which is good for around 280whp i believe. so the VVT system helps with low end tq to elimate that turbo lag feel, the only thing is that it doesn't come with larger injectors. they're still running on 370cc injectors. the S15 comes with 480cc injectors which can support that 280whp range. i would get the S14 engine and find some used S15 480cc injectors for like $250 then run it with the SAFC.
if your planning to upgrade the turbo anyways, then the S13 SR is better because they have better flowing heads, and is cheaper to buy.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 03-28-2005, 11:56 PM
The S14 has VTC (variable intake timing), a low port head, and has 370cc injectors like tat said. The S15 has 444cc injectors and pretty much the same head and timing controls as the S15. It even uses the same size turbo, but is made of better ceramic material and has a newer improved wastegate design for better flow.
1988 conquest TSI
Torque wins races!
Old 03-29-2005, 07:41 AM
Pavlo's Avatar
Pavlo Pavlo is offline
Correction: S14 SR20 has variable timing ONLY on the intake side, while S15 engine has VVT (variable valve timing) on both, the exhaust and the intake side. S15 also uses a GT turbo (think gt28-somethingm, please correct) and the S14 uses a T28.
VR6> Anything
FWD sucks for understeer? Swaybars do magic.
Old 03-29-2005, 11:16 AM
R.W.240's Avatar
R.W.240 R.W.240 is offline
Banned
Re: Re: Thought I should throw this out there...
The S15 just has a Ball Bearing T28. The GT28 is some wack aftermarket turbo with a t25 exhaust and huge Compressor. The GT28RS on the other hand...
Old 03-29-2005, 06:38 PM
i think your all wrong, but hey, everyone has there own opinion...
1988 conquest TSI
Torque wins races!
Old 03-29-2005, 06:45 PM
logik23's Avatar
Banned
If anyone was paying attention, you would know he was planning for the Blitz turbo kit and he's worried about money so the S13 is his best bet, end of discussion.
Old 03-29-2005, 07:10 PM
the VVT isnt useful after you upgrade the turbo? I would still probably get a S14 because it would be easier to find one with lower miles...
1988 conquest TSI
Torque wins races!
