Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 03-28-2005, 07:15 PM
eastcoastdriver's Avatar
eastcoastdriver eastcoastdriver is offline
99 ram check engine
hey i own a 99 ram 1500 and my check engine light keeps showing up and disappearing with no pattern. nothing seems to be wrong with truck and it has 60k miles on it. any ideas on wat to do would be appreciated because i dont feel like taking it to the dealer if its nothing.
Old 03-28-2005, 09:48 PM
crazys182003's Avatar
crazys182003 crazys182003 is offline
Re: 99 ram check engine
What I would do is head to an autozone and have them pull the codes for you. They can explain what they think it is but I would post back ehre with the code and maybe someone more knowldgeable about the codes can help. I am thinking it should be a 4 digit code on a 99. They will be able to pull off codes up to about 100 or 1000 starts I am not exactly sure but I am sure if it threw a code at you they can retreive it.
Old 03-29-2005, 08:33 AM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
yep, that's what I would do also, take it to autozone and have them scan it for you.
just an example of how touchy those computers are, the check engine light on my wife's jeep would ocasionally come on, then go off again with no apparent pattern. I took it to autozone, and the code that it had was for an evap. system leak, turned out that the little vent thing in the gass cap was bad, new $6 gass cap, and no more check engine light.
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
Old 03-29-2005, 09:42 AM
thanx alot for the help ill go do that and let you guys know the results
Old 03-29-2005, 05:08 PM
went and got the code checked out it was p0138 which is the high voltage O2 sensor on the drivers side rear. ill do it myself but they want 85 bucks for the part. Thanks for the help guys
Old 03-29-2005, 08:13 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
How many O2 sensors are there on that truck?
My Mopars
Old 03-31-2005, 09:48 PM
magnum_2003 magnum_2003 is offline
Re: Re: 99 ram check engine
There are 2 sensors, because the 2nd one is out on my truck right now as well, anyway of getting around this and maybe get some better gas milage while doing it?
